Question about Carrier Beverage Air® Marketeer® MT12-1-B Commercial Refrigerator
Is it normal for the fan to run all of the time? Even when the compressor is off.
    President:
  • 1,218 Answers
Good day,
If it is a beverage cooler, then yes, that is normal. It allows the temp to remain constant from top to bottom. Domestic refrigerators as a rule shut the fan off with the compressor, but on most any commercial cooler regardless of it's application keeps the fans running all the time.
Posted on Aug 27, 2010
My Kenmore dehumidifier fan runs all the time & compressor kicks in & out. I the fan supposed to run continually.
yes if its less than two years old the new ones run the fan all the time and cycle the compressor off humidity of room , the fans even have speeds on some models so you can turn em down
Nov 08, 2014 | Dehumidifiers
My magic chef model ctn1911gew is not working properly makes a clicking sound and is not cold at all and fan on bottom is not running. please help
Are we talking about the fan near the compressor? It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. It will click trying to turn on untill the over load gets hot Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is not running could itself be the problem. It is needed to keep the freon, and the compressor cooled.
Oct 12, 2013 | Refrigerators
Rangemaster sxs cream . Why is my fridge and freezer the same temp ???? If anybody could give me an answer or solution.
Jason,
MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped. 3. Your condensing unit:(compressor, condenser fan, condenser coils) has a problem.
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Refrigerators
COMPRESSOR RUNS A LOT
Your model has a mechanical thermostat inside the control panel. I believe you have something else going on like a bad fan, start relay, capacitor. Something is causing the compressor to struggle to keep up and in turn causing the compressor to short cycle. If the thermostat has no control over run time then something like I explained is causing the problem. Here is a parts manual=> ED5VHEXVB04 Contact me if you would like my help, Thanks Sea Breeze
Feb 26, 2013 | Whirlpool Refrigerators
Evap fan runs constantly
The fan should run when the compressor runs.
Nov 23, 2012 | KitchenAid Refrigerators
Just purchased new kenmore refrigerator plugged in for 10 hours not even cool inside .motor or fan is running.
Is the fan running? Is the motor running? is the compressor running? Is the air cold? Is there water dripping in to the evaporator tray on top of compressor? Are the coils warm? It can take even longer sometimes I have seen 14-15 hours but not normally.
Mar 07, 2010 | Refrigerators
Does the fan is on all the time?
old subzeros the CONDENSER FAN MOTOR RUNS OLD THE TIME. SAME WHIT THE EVAPORATOR FAN MOTOR. RUNS ALL THE TIME. now fos systems whit 2 compressor the condenser fan motor run for both compressor. only stop when both compressor stop......
Nov 25, 2009 | Sub-Zero 611 / O Bottom Freezer...
Freezer dying first, fridge failing...
Is the compressor running. also check to see if the fan next to compressor is running. They should both run at same time..is the compressor fan running and compressor not? Could be the compressor start relay. Next, is there frost buildup on inside back wall of freezer? If so u may have a defrost control out or defrost heater or defrost terminating thermostat out. Greg
Jun 11, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Fan / Compressor runs constantly
Condenser fans (the fan next to the compressor) do run all of the time. That is normal.
Sep 18, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Compressor wont start
It is probably a failed run capacitor for the compressor. Without the capacitor, the motor can't even try to run, but it will draw extreamly high amperage until it trips the thermal overload (avarage trip time 5-10sec) after it has a few second for the safety to cool off, it will try again. Either that or the compressor truly is seized
Jun 22, 2008 | Coleman Mach III Air Conditioner
Carrier Beverage Air® Marketeer® MT12-1-B Commercial Refrigerator Logo
156 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
