Question about Vtech DECT 6.0 Cordless Phone with Digital Answering System
Phone rings, press talk button, nothing happens.
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: keypad does not work
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, might I suggest a reset, remove power from the mains (unplug) and remove any and all batteries. This would simulate a reset. In some versions, there is a reset button inside a pinhole just for this purpose. Of course, doing so would revert the unit back to factory defaults and all user settings, configurations, memory would be erased.
Another strong possibility is diry, corroded battery terminals or its just that the battery is nearing end of life.
Worst case scenario is a component failure which then would require the services of a qualified technician.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 28, 2008
Panasonic kx-tga101s -- problem regarding making conference call - this is very much helpfull. But i have weird problem, i did call 1 person, and then i asked the person to hold and i made the other call....
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 26, 2011 | Panasonic KX-TG2740 Cordless Phone
The phones won't ring. One is on "do not disturb" And i don't know how to take it off. The other set is in french . I would like it back to english
  • HI TO SET YOUR RING TONE FOLLOW THESE INSTRUCTIONS:
  • Press the "Off" button on your GE 2.4Ghz cordless phone to ensure it is not in talk mode.2
  • Press the "Up" and "Down" arrows on the base of your phone and choose "Ringer tone."3
  • Choose "OK" and then choose Ringer Tone.4
  • Listen to each individual tone and choose the one that pleases your ear by selecting the "OK" button. There are six available ringer tones to choose from.
  • TO SET YOUR PHONES LANGUAGE FOLLOW THESE INSTRUCTIONS:
  • Press the "Menu" key found on the front of the base of the phone and scroll with the "Up" and "Down" buttons to "Language."
  • Press the "Menu" key again and select the language you wish to use with the arrow keys. Choose from English, French or Spanish. Once you have decided on the language preference press the "OK" button
  • THANKYOU
  • Dec 18, 2010 | Uniden Cordless Phone
    I want to change the nombers of the rings to get start the answering machin
    These are the instructions from the manual, which I found here:
    http://safemanuals.com/user-guide-instructions-owner-manual/GE/21028GE3-A-_E
    RING SELECT (FOR ANSWERING MACHINE)
    This feature lets you select the number of times you want to phone to ring
    before the answering system answers a call.
    1. Make sure your phone is OFF (not in talk mode).
    2. Press the MUTE/PROG button to go to the main menu.
    3. Press CID/VOL (up or down) button to scroll to HANDSET SETUP.
    4. Press MUTE/PROG button to confirm.
    5. Press the CID/VOL (up or down) button to scroll to the RING SELECT menu.
    6. Press MUTE/PROG button to enter the menu. RING SELECT 3 4 5 6 TS shows in the display.
    7. Use the CID/VOL (up or down) button to scroll to the your selection. The default setting is 5.
    8. Press the MUTE/PROG button to confirm. You will hear a confirmation tone and the new setting shows in the display.
    NOTE: If you select Toll Saver (TS) the unit answers after the 3rd ring if there
    are NEW messages, OR the unit answers after the 5th ring if there are NO new
    messages. This allows user to access their answerer from another location and
    then hang up after 4 rings to save long distance charges.
    Oct 13, 2010 | GE 21028GE3 Cordless Phone
    If you want to "make an announcement" using speaker phone using intercom, how do you do it
    When you intercom the extension, insert a STAR ("*") before the extension number.
    EX:
    Dial intercom 12, will ring 12.
    Dial intercom*12, will page the phone and go straight to speakerphone.
    IF the far end user has their "MIC/HFAI" button lit, they will need to do nothing, they can just talk.
    IF not, they will need to lift the handset, OR, press the "MIC/HFAI" button, to be head.
    Oct 05, 2010 | Lucent PARTNER18 Corded Phone
    The phones worked great for about a week and then they stopped working altogether. There isn't a dial tone but the phone does ring when there is a call. We press talk and nothing happens.What went wrong...
    it sounds to me like you just got a hold of some faulty units. if you have the reciept i subjest you return them or have the store you bought them from replace them. your units should work longer than a week.
    the problem your speaking of is a manafacture fault.
    return or have them replaced.
    Nov 12, 2009 | Panasonic KX-TG1033S Cordless Phone
    How do i use the intercom on my Uniden dect. 6.0?
    March 25, 2013 - INTERCOM INSTRUCTIONS
    Here is the answer! Press the INTERCOM button one time.
    The INTERCOM display will show on the screen.
    Use the UP or DOWN arrow button to select the HANDSET number.
    Press the MENU/SELECT button to ring the HANDSET selected.
    Press the END button when done talking
    Sep 01, 2009 | Uniden DECT 6.0 Cordless Telephone...
    Uniden 900 MHz EXS 9110 is dead
    Sound to me like you just need to replace the battery pack. Radio shack is a great place for phone batteries. If not, try www.batteriesplus.com
    Good luck.
    Apr 16, 2009 | Uniden EXS2060 Digital Spread Spectrum 900...
    THEFAX IS PICKING UP THE LINE AND NOT GIVING ME THE OPPORTUNITY TO PICK UP THE PHONE TO TALK
    On the operation panel, press the following buttons to select DRPD.
    1. Press <Fax>.
    2. Press <Menu>.
    3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
    4. Press the right or left arrow button to select [DRPD], then press <OK>.
    5. Press <Stop/Reset> repeatedly to return to fax standby mode.
    On the operation panel, press the following buttons to select the correct ring pattern.
    1. Press <Fax>.
    2. Press <Menu>.
    3. Press the right or left arrow button to select [RX SETTINGS], then press <OK>.
    4. Press the right or left arrow button to select [DRPD:FAX RNG PAT], then press <OK>.
    5. Select the proper ring pattern: NORMAL RING / DOUBLE RING / SHORT-SHORT-LONG / SHORT-LONG-SHORT / OTHER RING TYPE . Press <OK>.
    6. Press <Stop/Reset> to return to fax standby mode.
    Feb 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Both phones don't work at same time
    after reading fine print, that is how they are suppose to work. Only one works at time.
    Aug 21, 2007 | GE 27831GE2 Phone
    Vtech DECT 6.0 Cordless Phone with Digital Answering System Logo
    22 people viewed this question
    Top Vtech Lands Phones Experts
    Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
