Question about Samsung Syncmaster 940BW LCD Monitor
When i open the screen i get an indication "not optimum mode Recomended mode 1400 x 900 60 Hz but i can't find a way to adjust it!
    Sergeant:
  • 223 Answers
This setting is set in windows, right click on your desktop, go to either graphic options or properties and look for a resolution slider, the more you increase the slider the higher you resolution, but smaller the graphics on the screen, if the slider wont go that far or does not have that resolution you will need to change your monitor driver. in the same window, click advanced, monitor settings, look under the driver tab. you may need to download a driver for you monitor and operating system, if its not listed.
Posted on Aug 27, 2010
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Glad to hear this helped. I welcome Testimonials
    Take care!
I have samsung syncmaster sa300 20 led monitor, How to fix Not Optimum Mode Recommended Mode 1600 x 900 60 Hz analog, can not playing games
hi
im from iran
i have a monitor samsung sa300 18.5" that one of ics burn and i cant read his number its 8 pin and is up of the data port input. two crakter that begin by it , is at **22
please help me
Feb 09, 2012 | Computers & Internet
I have a Samsung SyncMaster 901B, it's not new, a friend gave it too me, i connected it to my computer,i start the computer, it works fine until windows finishes loading, then the screen goes black and i...
What happen when you hook this monitor up to other PC that has the video setting 1280 X 1024 60 Hz? Just ant to narrow down the problem before opening up the monitor. You may have logic problem in the logic board. If it does the same with other PC, then open it up and inpsect the inside for such thing as failed caps on the logic board or on the main power supply board, I think more likely to be ROM chip on the logic board is scrambled.
See typical failed monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 30, 2010 | Computers & Internet
How do I change the setting on my Syncmaster monitor if I can't see anything but the message box..."Not Optimum Mode recommended mode 1280x1024 60 hz?
You could try pressing the auto adjust button (simply says 'Auto'), and see if that changes anything...don't know if this will work, but it is a start.
Sep 29, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
Monitor stops working and box start floating around on screen with "Not Optimum Mode -- Recommended Mode 1280 X 1024 60 Hz." Replacement monitor works on computer.
check if your monitor has an auto-adjust button, this will help you autoadjusting the recommended resolution so that there are no problems, if not, you can try to rightclick on windows desktop and go to properties>configuration, set the resolution there
Sep 16, 2009 | Computers & Internet
My screen is showing message "Not optimum Mode, Recomended Mode : 1024 x 768 60Mhz. ?
you need to change your video adapter resolution to this one,if you can`t see nothing in normal moe login in safe mode(tap f8 on boot)and change resolution then restart
Jun 13, 2009 | Samsung SyncMaster 510N 15" LCD Monitor
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
TFT Problem
This LCD can work at 75 Hz refresh rate, btw much more healthy for your eyes, you can change it accessing Control Panel -> Display -> settings -> Advanced -> Monitor -> Screen Refresh Rate -> select 75 Hz.
Dec 07, 2007 | Samsung SyncMaster 152N 15" LCD Monitor
Monitor goes black
Does it show a picture in safe mode? If it does you might want to install drivers specific to the Monitor if you can find them.
Jun 18, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
Open Questions:
See all Samsung Syncmaster 940BW LCD Monitor Questions
Samsung Syncmaster 940BW LCD Monitor Logo
75 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
