Question about Jenn-Air JES9750 Electric Kitchen Range
My jenn air had a boil over and water shorted burners, Cleaned up switched burners to other side and switched grill to burner side burners tested good grill would not, No power after boil over to that side indicator light by switches lighting but there doesnt seem to be any power at burner plug any suggestions?
  • 4,924 Answers
Follow the power line ..and see if it has something is shorted ..or if it leads to a fuse...it is possible that the fuse its out ..and this stopped the power on that line .....or also check with a control lamp ..if there is current on the line ,,and until where ..this way you will see where it is interrupted ....see on the switches..in front of them and beyond..to see if there isn't any issue with it ..and like I said ..my money will go for a fuse blown..
Posted on Aug 27, 2010
I have a Jenn Air S160 stove and the burners stopped working. Is there a reset button? The grill does work on one side but the burners do not. Thanks, Pam
Try switching the grill to the other side if it works the ceramic burner is bad replace the ceramic burner. burners and grill coils unplug when you pull them out. The left one pulls out from the front the right one pulls put from the rear. you can enterchange the burners on either side.
Oct 07, 2010 | Jenn-Air Kitchen Ranges
Jenn-Air Model 720-0061-LP. Burners will not
burner is blocked needs cleaning out remove burner and clean it or put it in clr , or buy new one
May 18, 2010 | Grilling
Jenn-air model 720-0061 LP burners only light on one side cleaned with wirebrush and blew out with air?
The crossover for the flame to "jump" to the other side of the burner is clogged, rusgted, etc. It looks like a straight cut line on the rear under side of the burner. Nexgrill told me that the burners did not have an adequate amount of "finish" on them. Call them and get all new burners for free under warranty, Since 2004, I am on my 5th set of burners.
May 05, 2010 | Jenn-Air JLG7130A
I have a Jenn-Air grill with three burners. When I light the first two burners, they light fine, when I light the third burner, the flames on all three burners get real weak and the grill will not go...
Screwy new tank has safety feature: so...
remove the tank and clear the the lines.then reinstall the tank and crack open the vave just a hair. Retry. Seen it.
Sep 14, 2009 | Jenn-Air JLG7130A
How do I adjust the flame to burn hotter or more.
There are adjustment screw at the end of the burner tubes that allow more or less air to enter the burners. try opening or closing these screws
Jun 01, 2009 | Jenn-Air JLG7130A
Outside grill
I have had this same problem with my 4 burners.
I removed the burners and at the rear of the burner about 4 holes down is a canal that runs to the right side. I cleaned this canal with a paper clip and now my burners on the right side are burning.
Hope this works for you.
Aug 27, 2008 | Jenn-Air JLG7130A
Jenn-Air grill half burner issue
Re: only one side lighting, it is a problem with the cross over **** that carries the flame from one side of the burner to the other. It is located at the rear bottom of the burner and is probably clogged. Wire brush them to clean; failing that, replace with new ones and keep the new ones cleaned with a wire brush regularly.
May 31, 2008 | Grilling
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Jenn-Air JES9750 Electric Kitchen Range Logo
75 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
