Question about Dryers
I'm using a Bosch Axxis dryer for the first time. The dryer seems to run for a minute, cut out for a minute, run again, cut out again etc. Is this normal? I'm renting this place for a month and there are no instructions for the dryer. I wouldn't want to be doing some damage to the dryer. Please advise.
  • Dryers Master
  • 2,605 Answers
Werlcome to FixYa.
That is indeed perfectly normal. It is actually changing direction each time it stops and starts. That`s how those particular Bosch operate.
On another note, if you operate the unit on the "auto dry" cycles without enough items or extremely light weight materials in it, the dryer will stop since it cannot "sense" the garments.
Otherwise it`s all good !
Good luck.
Thank you for choosing FixYa today. Please take a moment to rate the info provided here today.
Regards,
Macmarkus :)
Posted on Aug 27, 2010
Testimonial: "Just what I needed to know. Thanks!"
My dryer runs jus for few seconds an cuts off then cuts right back on its usually differant amounts of time till it cuts off
i would say your motor has had it but check with a new caps first but usually these appliances have a protection overload to prevent burning your house down
Jul 11, 2014 | Bosch Axxis WTA 3500 Dryer
Heats spins but doesnt dry. its clean and lint free there is no exterior vent on it bosch axxis v20-ul thx
If you have heat, then it's an airflow issue as inside your dryer you have several thermostats, one is called the high limit thermostat, when the dryer can not vent properly, the heat builds up in the dryer and this thermostat cuts off the heating element for safety reasons, and the heat may not come back on for 20 minutes, I understand there is no exterior vent but the dryer does vent air. More then likely once you take the dryer apart and clean the lint out of the inside it will run correctly. Hope this helps Tim
Mar 11, 2011 | Bosch Dryers
Bosch WTL5400 Drier runs fine for 5/10 minutes, then it stops and the "start" light flashes. Pressing this then restarts the process, but a few minutes later it cuts out again. I have checked...
I have the same problem, the dial to select the dry program is making a bad contact causing it to stop. Try using a different program.
I tried to clean the dial but it didn't help.
Dec 06, 2010 | Bosch Axxis WTL 5400 Dryer
I have an axxis not drying and code F:03 comes up
Most likely your wall vent is restricted. Unhook dryer from wall vent and pull away from wall. If you don't get code your wall vent needs to be cleaned.
If unit still gives code sensor is either bad or theres a restrictions inside machine, likely in the blower wheel hosing. Air flow when running should be strong coming out of vent. many times strength of a blow dryer.
Jul 18, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
Bosch Axxis Starts and stops
The lint light keeps coming on and shuts the dryer off so clothes are not dry. I checked the filter and it is clear. Now the bottom of filter is cracked (plastic part) so I need to replace. But why does the lint light come on now after 5 years of use? It never came on before even when the lint filter was full?
Apr 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Only a little heat is going to the cylinder
Zuraxus what you are seeing is normal for a time. Here is how this dryer works. With a wet towel in the dryer, the first 5 minutes is testing to see if the load is wet. If so then between 5 & 10 minutes the dryer will turn on the 800 watt heater section (only in clockwise rotation). If still wet enough from 10 minutes to 15 minutes it will turn on the 1900 watt heater (heating only in clockwise). If still wet enough 15 to dry will turn on the full 2700 watts in clockwise and 800 watts in counter clock wise. That is how the cycle works. However it is hard to tell with the rear cover removed as the blower pushes the air thru the heater. Careful that by running with the back panel off you don't trip the high temp manual reset protector. So yes this sounds normal. What is the issue that is causing you to think the dryer isn't working proper?
Apr 20, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch dryer
I had this problem for an axxis condensation WTL5410.
When starting dryer ligghts on front would cycle through normally as if dryer were running but dryer would not turn or get hot.
The problem was the door switch.  Push in the door switch activator on the bottom right of the dryer.  Push it hard a few times and try the dyer again.
doesnt sound like a great solution - but after 150$ and 2 service calls - it was what fixed it for us.
Jan 14, 2008 | Bosch Axxis WTL 6003 Electric Dryer
Dryers Logo
159 people viewed this question
Top Dryers Experts
