My WD-62527 screan appears to have green and purple spots that dont move with the picture. I cleaned the screen on the front and back. Not sure if there is dust on the lens. Not sure how to get inside to clean it. What is wrong with my TV?
  • 57 Answers
This is often caused by placing speakers near your televison(but not the only cause) unfortunately this is permanent and there is no cost effective way to fix it. Sorry
Sincerly
Kieran.c
Posted on Aug 27, 2010
My tv a mitsubishi d 62527 the green light kees blinking
Called the blinking green light of death---set should if power lost when put back blink for 70 seconds or so---digital unit booting up.
About the only simple cause is in the main power supply are four 1000 uf caps that puff up and fail--provide boot up voltage.
follower power cord to supply and look for bad caps (they will be easy to spot) and see attached photos of what to look for.
Nov 06, 2012 | Mitsubishi WD-62527 Compatible TV Lamp
Purple spot on kdf-e60a20. Screen
its possible something in this DLP is on the lens that projects the picture onto the screen or the mirror (do not touch it) or between the lens and the inside of the screen---anything will if there show up in the picture.
In some cases I have used compressed air to dust these out but carefully.
Nov 04, 2012 | Sony KDF-E60A20 60 in. LCD HDTV
Mitsubishi wd 62527 has very dark picture changed
Clean the small front projection mirror. That mirror can get dust on it and will cause the projected image to appear dull and dim and cleaning that mirror will usually restore the brightness and crisp details in the image.
Oct 20, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Screen Removal - Mitsubishi WD-62527
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
Aug 01, 2009 | Mitsubishi WD-65735 Television
Purple blotches on Mitsubishi WD 52527
yes you can clean it. i clean mine all the time. after you remove the screws at the bottom you should be able to just lift it up. it will be hard be cause there is sticky tape with a hinge that the hole screen sould just lift off. i know it doesnt feel like it but it will. just do one side at a time. now the problem with the purple spots are because you move a speaker to close to the front of the tv the was not shielded and cause it to do this. you can move the tv so that the earths magnetic field will restore it for you. make sure the tv is not plugged in when you move it for 2 to 3 days . after the 2 to 3 days plug tv back in and leave on for 2 hours. after this you can move it back and plug back in. this should fix it. if not you will need it to be degoudged. tv repair center can do this at your home. hope this help you.... thanks eddy
Jan 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Light purple spots on my screen
Unfortunately, this sounds like a problem with your TV's lamp. They are not cheap to fix. Search Ebay for a new lamp and get someone to install it for you. These Mitsubishis have a design flaw that make the lamps burn out quickly.
One thing that will PREVENT this problem is making sure that the TV's vents are clean.
Dec 29, 2008 | Mitsubishi WD-62528 62 in. LCD Television
Screan turned a shade of purple
I believe you have lost the green channel leaving only the red and blue. It could be an internal connection like a solder joint or connector, or it could be component failure from the CRT to an adjustment pot. Being the set is ten years old it wouldn't be worth spending a lot of money on it. You can buy a 27 inch TV now for almost what a repair would cost. If the picture was very good before this probem you may try to get it fixed cheap. Otherwise it probably wouldn't be worth it.
My 27 inch TV's (A Sony and a Sharp) are pretty old and I would fix them myself if the picture tube was very good.
This may be a very good time to buy considering the discounts being offered. ;-)).
Nov 21, 2008 | RCA Televison & Video
Random purple spots on screen
I have the same issue with the WD-52528. I was told it may be a bad light engine. Service is coming out August 27th. I'll let you know what they say.
Aug 21, 2008 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
