I'm trying to download Rosetta Stone. When trying to download application disc, I get an error box stating" setup was unable to find the msi package or patch." Canyou help me?
pgmadhav
  • 145 Answers
SOURCE: unable to uninstall Fix-It Utilities 8
Use REVO uninstaller. It is free and good uninstall utility
Posted on Dec 14, 2008
SOURCE: Headset Problem Rosetta Stone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Posted on May 07, 2009
bluecrash
  • 106 Answers
SOURCE: When Rosetta stone installation tells me to put in
You can get the fixed file and details here:
http://support.rosettastone.com/ics/support/default.asp?deptID=14006
Posted on Jun 25, 2009
  • 30 Answers
SOURCE: My computer completely crashed and
sounds like you may have to go back to where you bought the software and tell them what happened - maybe they will give you another key.
Posted on Jul 24, 2009
rajforu
  • 69 Answers
SOURCE: I use WINDOWS XP SP 2...mainboard MSI N1996,
It is fault in Ur Windows firstly repair Ur windows then install driver but recommended restore backup must.
Posted on Feb 25, 2010
Rosetta stone 9114 on mac
You get Error 9114 on Rosetta Stone if you have a bad disc or secutity settings. Find the fix at Questions Rosetta Stone Community
Jul 02, 2014 | Rosetta Stone 3 Farsi Level 1 2_3 Set Full...
Error 9119, 9114 rosetta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure and delete the Garbage Files. Good luck and spread the word.
Dec 29, 2012 | Rosetta Stone Computers & Internet
Fatal error code 2124 on Rosetta stone
There is file called tracking.db3 which gives us lot of error like 2124, 5611, 2123 etc.... you can find a perfect fix at Questions Rosetta Stone Community
Jan 03, 2012 | Rosetta Stone 1, 2, 3, 4 & 5 Set English...
I have a Rosetta Stone V 3.4.5 and Win Xp. Rosetta Stone doesnt recognize the mic. What can I do to fix this error. The number of th error is 1117. My OS is Win Xp Waiting for help Alex
Create a security exception. 1. In ESET NOD32 (Smart Security 5), click Setup.
2. On the Setup screen, click Enter advanced setup... (bottom of screen).
3. On the Advanced setup screen, open Computer -> Antivirus and antispyware -> Exclusions.
4. Click Add , locate/select the Rosetta Stone Version 3 executable, then click OK. (In my case, the executable was in the C:\Program Files (x86)\Rosetta Stone Version 3 folder.)
5. Click OK on the Advanced setup screen.
Set the Rosetta Stone compatibility mode. 1. Right click the Rosetta Stone desktop icon or Start -> All programs -> Rosetta Stone.
2. Select Properties from the list.
3. Select the Compatibility tab.
4. Check the Run this program in compatibility mode box.
5. In the list below the check box, select the OS (in my case, Windows 7).
6. Click OK.
Sep 23, 2011 | Rosetta Stone Spanish (Latin American) -...
Loaded Start disc. When installing my language disc 1, I get an 9123 error code and a message " there was an error in the application". I cannot uninstall, because I get messages "...
Version 3/4: Error 9123 during Language CD installation
This error message relates to Version 3 and Version4. If you receive a 9123 error message during language installation, try one of the following resolutions:
  • Clean the disc with alcohol/windex/water and a soft cloth and try installing again.
  • Disable your internet security program, especially Norton or Symantec Security and try installing again.
If you are still experiencing this error, please contact Rosetta Stone Support
Dec 23, 2010 | Rosetta Stone Chinese Mandarin Level I &...
I tried to install the Rosetta Stone CD for Spanish 1 and could not find an installer. What should I do? Is there an Installer I could download?
when you insert the disc right click on the cd drive and then click open
Highlight all the files in the folder and then copy them and paste them on a new folder on your desktop.
Once when the copying is completed remove the disc and then double click on the setup file from the folder saved on your desktop and then install it using the product key which came along with Rosetta Stone CD
Dec 19, 2010 | Rosetta Stone Spanish (Latin American) -...
Error 2123 appears when loading rosetta stone
I started getting "Error 2123" recently, and spent A LOT of time searching for the fix. Here is what finally worked:
Find the hidden file "tracking.db3". It's in the hidden folder "ProgramData/Rosetta Stone" under the "C:" directory. Copy and paste it to the Rosetta Stone install directory (Program Files/Rosetta Stone).
Error 2123 should be gone, but now there will be Error 2125. So, in the Rosetta Stone install directory, run the "service_installer" .exe file by double-clicking it.
Feb 20, 2010 | Rosetta Stone Japanese Level 1 & 2 for...
After uploading the application software for Rosetta Stone, I try and start the application and I receive: there was an error in the application. error 2123. How do I fix this problem for my iBook G4...
Feb 02, 2010 | Rosetta Stone Spanish Spain Level I & II...
There is an error with this application
Nov 23, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Computers & Internet Logo
207 people viewed this question
David Payne
David Payne
