Question about Compaq FP 7020 17" Flat Panel LCD Monitor
I turn on the monitor and Compaq 7020 comes on the screen in color for about 2 seconds then goes black. The computer is on and everything is plugged in correctly
    Sergeant:
  • 223 Answers
Use a flahlight see if you can see an image faintly in the screen, if so the backlight is failing. if not, check your VGA or DVI cable connection on both ends. sometimes there is more than one port on the back of the computer, try the other port if you have two of them,
Posted on Aug 27, 2010
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Does my response answer your question? do you need further clarification or help? Please use the solution rating if your problem has been solved, or make a note if your still having trouble.
    Thanks! Gurvy
Compaq Monitor 7020 adjusting...
Try monitor on another PC / laptop, if still no go it will be either faulty cable or monitor.If it works then the video card is faulty or needs to be reset in the slot.....you haven't said if its a PC / laptop.
its pc not laptop,but when i use other monitor for that pc it works
Jan 24, 2010 | Compaq FP 7020 17" Flat Panel LCD Monitor
Our compaq monitor will not go on. It is plugged in and the green light goes on when the button is pushed, but nothing comes up on the screen after moving the mouse. Our Presario computer is turned on. Any...
Make sure it is properly plugged into your computer too. (blue headed cord) should go from the screen to the computer. Make sure the cord is not damaged.
There should be a total of two cords needed (one for power (black) and (one from the computer to screen (usually blue))
Oct 18, 2009 | Compaq 15 COLOR MONITOR***
My dell monitor 1703fps comes on for about 2 seconds
i think if you can service your monitor please see all the filter capacitor i think capacitors leak and need for replacement.
Sep 28, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
OSD LOCKED in Compaq LCD 17" Model No. 7020
I had this problem with a different model. try this.
. turn off the monitor.
. press and hold the Menu key while you turn on the monitor again.
Jul 21, 2008 | Compaq FP 7020 17" Flat Panel LCD Monitor
Removing the case for a Compaq 7020 17 in LCD monitor
The case has 2 plastic snaps en each side as well as 3 snaps at the top
Use a flat-head screwdriver in the **** between the gray and black plastic. Twist the gray plastic away from the black plastic, and this will snap the part appart
Apr 24, 2008 | Compaq FP 7020 17" Flat Panel LCD Monitor
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Compaq FP 7020 17" Flat Panel LCD Monitor Logo
116 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
