Vulcan eco 120 stoped working, checked fault codes and it said hot serface igntier. i changed that and tryed operation, unit still dose not light. when i press reset fault codes say failure to light, but sometims it also says slow closung gas valve. how can i fix it?
hotuna
  • 288 Answers
SOURCE: Vulcan ducted heating not working
How many wires for the thermostat do you have? If you tell me I can help. The green flashing, instead of red, in my experience, means a thermostat problem.
Posted on Mar 05, 2008
gamerfixer07
  • 344 Answers
SOURCE: Unit in room displays fault
Hello susiec65,
This may be a filter cleaning reminder that Sharp has included in all of thier modern air units. Try this to resolve the issue.
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
If you doubt the veracity of this information, or it does not work as
expected, you can get it directly from the source at:
1-800-237-4277
which is the Sharp customer service line. But, you'll need to call
between 7 AM and 7 PM US Central time, and have your model number and
serial number ready.
I hope this helps you. Good luck and thank you for using FixYa!!
Posted on Aug 02, 2008
  • 10865 Answers
SOURCE: I dont know what ECO failure means or how to fix it.
This water heater is equipped with a control which has a built inE.C.O. (Energy Cut-Off). The E.C.O. will shut the gas off,
should the outlet water temperature exceed 200 F. If the
E.C.O. has tripped, the entire gas control must be replaced.
For gas control replacement, contact your local gas utility, or a
qualified service technician. The replacement control must be
an identical model to the control which has been removed.
Posted on Jan 27, 2009
  • 4 Answers
SOURCE: GG50T06PVJ 2 yr old unit, no hot H2O, ECO Failure code.
Parts should still be under warranty. Call the manufacture at 800-432-8373.. Have your model & serial number. A tech agent should be able to assist you.
Posted on Mar 10, 2009
  • 8 Answers
SOURCE: No flame on left side/main valve. Right side lights, flames up
Try taking out the orifice on the burner that is not lighting and make sure it isn't blocked.
Posted on Mar 12, 2009
My eco lights are not on and my engine light is on my 2010 jeep grand cherokee 3.7 liter
When the check engine light is on eco (economy) is disabled. You now need to have the OBD2 fault codes read, this is done at the diagnostic port under the dash on drivers side with a OBD2 scanner or code reader. Also Autozone parts stores will do the test for free.
Mar 20, 2017 | 2010 Jeep Grand Cherokee
Refrigeration code on scotsman ice machine model cme506as-32f.What could be the cause?
Unit is off& Refrigeration diagnostic light is on or blinking. Possible Cause,( Low discharge or long freeze cycle. Probable correction, if the Refrigeration light is glowing steadily there is a probable refrigeration problem.) 2. Possible cause. Harvest problem. Probable Correction. If refrigeration light blinks once and repeats, Look for a harvest Problem.**On Controllers 17-1 and higher, This also indicates that cubes were (sensed) by the bin controls. 3. Possible Cause. Hot gas valve failure, Probable Correction. Check hot gas valve operation. 4. Possible Cause, High Discharge Temp. Probable Correction, If the refrigeration diagnostic light blinks 3 times and then repeats, check for a reason for high discharge temperatures. 5. possible Cause, Harvest problem. Probable Correction, Controllers 17-1 and higher, if the light blinks 2 times and repeats, check for a harvest error- no cubes sensed. 6. Possible Cause, Unit dose not go into harvest - exceeds maximum freeze time. Probable Correction, Push and release off button. Push and release Freeze button. Check operation. next Push cube size float down and check operation. 7. Possible Cause, Exceeds maxi harvest time. Probable Correction, Check for cause of long harvest cycle. Try not to put any gauges on system until you have to. Every time you do you loose refrigerant out of the system.
May 02, 2014 | Kitchen Appliances - Others
Sparks coming from underneath turntable.
check for black spot on support for turn table and floor of unit, sand them back to the metal serface and paint if cavity is not stainless steel, if turn table is not turning replace the motor as this could cause this issue as well.
Feb 04, 2010 | GE Advantium 120 Convection/Microwave Oven
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Break light does not work and the two small head lights as well.
the break light not working could be due to the pedal sensor not connected or faulty .check also the wiring loom under the seat as it could be disconnected .
in regards to the small headlights , check all fuses as you could have blown fuses as well .
contacts could also oxidise and not making contacts
Sep 27, 2009 | 2004 kawasaki VN 1500 Vulcan Classic
Burner lights but will not shut off. then pressure
CHECK TO MAKE SURE THE WATER TEMP IS AT THE NORMAL OPERATING RANGE. USUALLY AROUND 120-130 DEGREES. IF IT IS, CHANGE OUT THE PRESSURE RELIEF VALVE. IF THE TEMP IS OUT OF SCALE, CHANGE OUT THE ECO AND TSTAT.
Jun 28, 2009 | RTO Atwood Water Heater - 6 Gal LP
Code 49 and Manual Book
Fault 49 usually points to the cold inlet valve. I have come across many with this fault that the valve tests ok and it needs the motor controller replaced.
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Whirlpool ADP4542 Flashes 7 times
If that's the clean lite flashing that is a fault code. That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold.
Jan 04, 2009 | Dishwashers
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
