Question about Maytag Dryers
My Matag Epic Z dryer started to have a problem with water collecting in the drum of the dryer. It has been a great dryer but now it is not working well due to this problem. Can you help me?
  • 10,319 Answers
Clean out the entire venting system inside this dryer. It has to be clogged up holding back the moister
Posted on Aug 27, 2010
Water not collecting at base of pull out drum
hi make sure condenser box is clean that is one with metal plates if so make sure were filter goes is clear maybe blockage
Feb 12, 2014 | Hotpoint TDC32 Electric Dryer
I just moved and my matag epic z dryers will not start. I have power to the back of the dryer. The power switch feels like it is stuck in......
the start swith is momentry with the switch stuck you woild have to break the the conecton by pulling one wire off the switch and tuching the outher wire momentary do not conect if this works its the switch pull the plug before you trythisthen pull wire off put back the plug then try the test .
Jul 19, 2013 | Dryers
Maytag Epic Dryer Model MED9700SQ0, everything lights up, power is on, but drum will not turn and no heat.
Can you tell if the motor comes on? If it does, then it could be a broken belt.
Sep 01, 2012 | Dryers
MY MATAG #MDE9316AYW RUBBING SOUND NO START WHEN HOT
the drum of the dryer that holds the clothes has a seal surrounding the entire front of the drum. once dried out alot of build up is accumulated and will cause your problem. also the belt and tensioner should be looked at as well when opened up for inspection
Feb 06, 2010 | Dryers
Matag performa dryer heats but won't tumble.
After checking the door switch and belt (both ok) I took the wires
from the thermal fuses-- straight wired them together and the dryer started working. I went to my local appliance center,
purchased the thermal fuse kit --replaced the old fuses--now it
runs great.
I hope this helps someone else with this problem.
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
DIAGRAM OR INSTRUCTIONS BELT INSTALLING MATAG DRYER DE412
belt goes around drum and around pulley on motor and under tentioner
Feb 18, 2009 | Maytag Dryers
Dryer motor will not spin..motor sounds like it is sutck.
Get a putty knife, release the top by pressing the springclips between the front and top.
Then remove the front. The blower wheel may be the problem. They get loose.
Jan 04, 2009 | Maytag Performa PAV2200
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
