Question about Panasonic sa-ht800V Home Theater Audio System SA-HT800V System
NO DISC message
The DVD worked fine a few days ago. Today I put in a DVD and got a NO DISC message. I've tried 3 different DVD's and the same message.
I've had this home theater for about 4 years and its worked fine up until now.
My other components (speakers SB-FS803, SB-PC803, SB-WA312) are fine. If I can't fix the receiver, can I purchase any other receiver that can use these speakers?
  • 4,234 Answers
Open up the unit and clean the lens using a cotton swab and alcohol. If that does not resolve the problem, try a music CD and report the results here. I suspect that the optics have begun to fail. If that is the case, the music CD will play but a DVD will not. The optics assembly is available (part # RAF3023A-1) for about $60.
Dan
Posted on May 06, 2008
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: NO DISC message
Hi there
I would suggest cleaning the laser lens with a lens cleaner disc first
Where are the laser lenses located?
Posted on Jun 06, 2008
redhead7377
  • 51 Answers
SOURCE: My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
Posted on Jul 25, 2008
redhead7377
  • 51 Answers
SOURCE: "NO DISC message"
laser is bad...
NO DISC message
Hi there
May 06, 2008 | Panasonic sa-ht800V Home Theater Audio...
I have bought Pioneer DVD player 420V few days ago, but when I put disc I got message on the TV that DVD can not play because the region code is not recognized. Should I reset all systems or???. I need...
the region code means the player does not support the disc your playing each country is given a region code for dvd australias is region 4 if you buy a dvd from another country it wont work you can get multi region codes for dvd players im not sure of pioneers code but try using a dvd from your country region and youl find it works just fine you can also try asking a tech on fixya for the multi region code for the model dvd player you have.
best of luck
merry christmas
Dec 22, 2010 | Pioneer DV-490V-K DVD Player
NO DISC message
I assume that problem is dirt on laser lenses. If you don’t get any result after this, than you can replace receiver with new one. If you want to use your existing speakers with new receiver with integrated amplifier, you must pay attention on wattage, to be same like old one (i.e. 100W), and also resistance (i.e. 4 ohm). If it’s same like old receiver, you should have no problem. Good luck.
Panasonic-SA-HT800V problem
what has gone wrong is there is some sort of module in the back i too kmine apart and noticed it was the only thing that could have caused an issue im tryin to see what it woiuld cost to fix
Wrong Disc message when trying to play a DVD
have same problem but mine has never worked. guess you get what you pay for.if anybody knows were i can get remote codes for the tv please post.
Apr 10, 2008 | TruTech PLV16320 Television
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
138 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
