Question about Maytag Dryers
The timer will not shut off, if you set it for 20 minutes, it never moves
    Champion:
  • 245 Answers
Change the timer it is bad! Rate me.
Posted on Aug 27, 2010
Hello, I have a Maytag legacy series washing machine and recently it stopped working properly, first it tripped the breaker, then in regular washing mode it washes normally but skips spinning and water...
Sounds like a bad relay array, or timer module. The little motor that makes the selector move (and then trip the function switches inside the timer module) could have trouble moving the selector past a certain point. When the machine stops, press your ear up against the timer module. Do you hear the little timer motor running? Yes? then it's probably the timer module itself, not the timer motor. I say this because you can manually move the selector to activate the modes.
Jan 03, 2014 | Maytag Legacy Series Top Load Washer
Whirlpool ultimate care ii dryer timer
Sounds like the knob is not on correctly, or is not the correct knob, or the plate with the numbers on it has moved. When it turns off naturally, does that line up with 'off'?
Nov 29, 2013 | Whirlpool Dryers
I have an Darlac Electronic water timer DW253 but haver mislaid the instructions, where can I download a set?
I cannot find a manual for the Darlac DW253.
It appears the timer is set by moving each selector knob.
http://www.watermate.co.uk/secure/uploads/DW253%20(Small)%20new%20darlac%20pop.jpg
Knob on right is Run Time:
This is how many minutes timer will run each time.
Set run time from 1 minute to 120 minutes.
Knob on right also has ON-OFF override.
Knob on left is Frequency:
This is how frequently the timer will turn ON. Once per hour, once per each 2 hours ... once per 24 hours ... once per 72 hour ... once per week.
So set frequency to 48 and set run time to 20, then every 48 hours the water will turn on for 20 minutes.
To turn timer off, move right knob to OFF.
For continuous watering, turn same knob to ON.
This timer is battery-powered, probably 9 Volt, but maybe AA.
Battery carriage appears to be located on front below the function knobs.
Typically, water timer batteries last one season.
Timer can be connected to household spigot, or connected to any passive water supply for example rain barrel or tank.
Appears to have standard female hose thread on top, or possibly 1/2 pipe thread, and quick connection on bottom.
Plastic water timer exposed to freezing temperatures can crack. Drain water out of timer during cold weather.
Generally if water timer stops working: replace battery, clean battery terminals, and if functionality is not restored, then buy another timer.
Add a comment to fill out the missing details.
Aug 02, 2011 | Woods Inwall 24 Hour Programmable Timer
Tv shuts off
check to see if tv is set on a timer to turn off?
Mar 21, 2009 | Philips Magnavox 20MT133S 20" TV
SHUTS OFF AFTER 1 HOUR
Here ya go!
Setting Auto Off (units with timer only)
On models with a glass carafe, the auto off can be set to shut the coffee machine off from 1 - 5
hours after the brew cycle is complete. The factory setting is 2 hours. On models with a thermal
carafe, the coffee machine shuts off after 20 minutes.
Note : On models without a timer the coffee machine must be turned off manually. It
will not automatically shut off.
• Press the prog button (o), immediately followed by the h/min button (n).
• The display will show the time setting.
• Press the h/min button in steps to set the auto off time.
• Press the prog button to confirm the setting.
Dec 30, 2008 | Krups FME2 Coffee Maker
Laptop shuts down
check the timer setting and set it to always on
Mar 18, 2008 | Compaq Armada M700 Notebook
Dryers Logo
14 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
