Question about Vizio L32 32 in. LCD HDTV
Picture too wide for screen losing words off both ends of screen
  • 57 Answers
Http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Copy and paste this into your browser it s the manual. but ths problem is just always your screen settings( example my tv has theater modes that stretch the screen just lke you described).
I m also going to go through the manual and see if i can find the awnser for you.
Posted on Aug 27, 2010
  • Kieran corrigan Aug 27, 2010
    open your menu at the top of your tv. second option from the right has a screen setting size. you can go between small medium and large also the far right option has a settng to change from wide mode, zoom, panoramic and normal.there is also a factory reset in this menu.
    hope this helps
  • swhitley383 Aug 27, 2010
    I've been in there and have the horizonal
Tv is not showing complete picture....some things are cut off
Change the aspect ratio.this can usually be done via the remote or through the tv menu.normal view for most wide screens is wide 16:9 but if you have zoom or crop black bars then you may lose parts of playback.
Feb 19, 2015 | Vizio L37 Television
Words at the bottom of the screen
See if you have a button called ARC on your tv remote.. you will have different modes called Wide, Zoom, normal etc., Just put it in normal mode!
Mar 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
I have a Vizio M260VA and the picture is cropped in too tight for the screen. Is there a way to set the picture so it fits the screen?
on your Vizio remote is the word WIDE, mine is in the lower left corner. Click on that and you will be given choices or different screen options.
Sep 25, 2014 | Vizio Televison & Video
How do I see the hole picture on my Philips match lll line. Black corridors on each side cuts away the sides of the picture. /t
You may actually be looking at the entire picture. The newer televisions have a 16:9 aspect ratio (16 units wide for every 9 units high). The older sets had a 4:3 aspect ration, and a lot of material was made for the 4:3 screens. There are three ways to look at this material on a wide screen set: use the "shadow box" you describe, stretch the picture sideways to fit the screen, or expand it to fit width and lose the top and bottom of the picture. Your choice depends on the material and your personal preference.
Now, if you know you are looking at wide screen material, you need to correct a setting in the view format options. These settings go by various names in the instruction manual and on-screen menus - "resolution", "aspect", or "display format" are common. I haven't seen the menus on a Phillips set, so I don't know what term they use.
Oct 24, 2010 | Televison & Video
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sanyo 42" 1080p, picture doesn't fit on screen
this is normal and this feature is for wide screen programs! normal shows and games will lose part of the top of the screen sides and bottem because it zooms in on whats in the middle of screen! hope this helps
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a TX32PM11C 32"
You have to turn off the "automatic", so the TV will not automatically show you what it wants you to see. Then, if you select 16:9 , you will see true widescreen.
Since you cannot physically change the size or shape of your TV, the picture itself will be black on the top and bottom. Since not all programs are widescreen, sometimes the sides will be black. You can try the other sizes to see which works best for you.
Apr 25, 2017 | Panasonic Televison & Video
Wide screen lcd simple question.
Hi pooing stone,
You may sometimes find that even with a television referred to as “widescreen,” widescreen movies still have letterboxing.
This is likely because the movie you are playing is still in the ratio used at a theater. While most televisions are 4:3 for the more square-type or 16:9 for widescreen, a theater screen is much wider still. Unless the movie has been reformatted specifically to 16:9 for your television, you will either see letterboxing or lose portions of the picture by zooming in.
If a movie is available in several ratios, I suggest thinking of all the options before buying. Although purchasing a movie reformatted to 16:9 will prevent the black bars, purchasing it without any reformatting of the size will prevent you losing part of the picture.
FYI: It is very common with Blu-Ray Discs that widescreen means original size, not 16:9.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 03, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
The writing on the screen is stretched beyond the width of the screen and I lose script on either side - I have checked the fine tuner on the remote but it doesn't seem to have the ability to fix the...
if you have a wide flatscreen tv it could be that the picture size is in the wrong mode. under the mode button on your tv remote should be two buttons labeled wide and zoom. try pushing these buttons to adjust the tv screen size.
May 02, 2008 | Televison & Video
Vizio 37'' TV
This is normal.
Oct 21, 2007 | Vizio L37 Television
Vizio L32 32 in. LCD HDTV Logo
199 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
