Question about Konica Minolta DiMAGE 7Hi Digital Camera
How do I format the card when it says card error on screen? I can not get the screen to change with the menu button
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 27, 2010
How do i format my sd card
1 Press the Menu button. 2 Press to highlight Setup Menu , then press the OK button. 3 Highlight Format , then press the OK button. 4.Highlight an option, then press the OK button: MEMORY CARD-deletes everything on the card; formats the card. CANCEL-exits without making a change. INTERNAL MEMORY-deletes everything in internal memory including email addresses and album names; formats the internal memory. 5.Highlight Continue Format, then press the OK button. (When the formatting is complete, the Setup menu appears)
Nov 09, 2010 | Kodak EasyShare CX6200 Digital Camera
Trying for format my memory card - keep receiving error message will not let me format
Follow these steps to format your memory card. In any mode, press the Menu button. Press to highlight Setup , then press the OK button.Press to highlight the setting you wish to change, then press the OK button.Choose an option, then press the OK button. Press the Menu button to exit.You will be having a setting named as format. Click that and format your card. This will reformat your card.
Thank you !!
May 24, 2010 | Kodak EasyShare C330 Digital Camera
When I turn the camera on I get the message "memory card error". The only button on the camera which then works is the menu button but it just brings up the screen and then the same error message. Yes, I...
You need to format the card in the camera. Go into the menu and scroll to "format" and follow the on-screen instructions. This will erase and initialize the card . To download pictures, the most trouble-free way is to use a card reader and download to a folder you create on your desktop.
Nov 14, 2009 | Pentax Optio S4i Digital Camera
Card Error
Are you getting this error with the card?
If so, insert the card into the computer. Make sure you get all the files off before you continue. Then go to my computer, right click on the drive, click properties, click the tools tab and click check now. Just do Automatically fix file system errors and click start. This should successfully find errors if present on the card and fix it. You may lose a picture or two if you don't transfer all of them first. Or you could format the card by right clicking on the card drive and clicking format.
If you get the error on the camera without the card in it, turn it on and click mode button twice to get to the picture display (it should be a black screen with "memory error" on top). Then press menu and use the 4-way button to go to the right for Setup. Then use the 4-way button to go down to format to format the camera.
This should fix it.
May 05, 2009 | Sanyo VPC-S880 Digital Camera
CARD ERROR--XD-picture card
I had the same problem; formatted it on the computer; still the same. I the got this info (below) from tomshardware site and it worked for me:
1. Turn the camera on (to Photography Mode, not Playback Mode).
2. Press the Menu/OK button.
3. Move left or right until you reach the Option Menu.
4. Move up to SET-UP and press the Menu/OK button.
5. There are 4 option screens. The Format option is in screen
number 1, so you should see it immediately.
6. Move down to Format and then either move right or press Menu/OK.
Jan 03, 2009 | Fuji xD MP3 Player
What does PICTURE ERROR mean? not in manual nor on line
Sounds like you will need to format the memory card as the card has become corrupted. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the picture error message and the card can be used again.
Dec 29, 2008 | Olympus SP-500 UZ Digital Camera
Olympus 850sw- write protect and picture error
Sounds as if the memory card has corrupted data on it now. You will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup Menu - right arrow to Format- Press Ok. You will see format yes or no. Choose Yes and press ok. This will clear the write protect and picture error messages and the card can be used again.
Dec 29, 2008 | Olympus Stylus 850SW Digital Camera
Tz3 ''write error, please check the card'' when taking picture.
Try formating the SD card by pressing center Menu button then scroll to end of Menu for FORMAT.
Nov 23, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Formatting memory stick.
You can use the MEMORY FORMAT functions to completely delete all images and options on the Memory Card, including protected images. * The format function restores the Memory Card to its initial state. * The Memory Card supplied with this camcorder has been formatted already. Attention If you execute the MEMORY FORMAT function, all images will be erased completely and erased images cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The sub menu will appear. 5. Select FORMAT from the list and press the ENTER button. 6. "ALL FILES ARE DELETED! FORMAT REALLY?" appears on the screen. 7. Using the MENU DIAL, select the item. NO : To return to previous menu YES : To start formatting. 8. Press the ENTER button. If you selected the YES, COMPLETE! appears on the screen when the MEMORY CARD formatting is finished. 9. To exit the menu, push the MENU button.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Konica Minolta DiMAGE 7Hi Digital Camera Logo
Top Konica Minolta Cameras Experts
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
