Question about Husqvarna Garden
When the blade is engaged the motor boggs down really bad ive checked the plugs the fuel filter air filter the blades and belts no restrictions
    Problem Solver:
  • 7 Answers
The mower part is controlled by the solenoid on the carburator. It controls the idle and the fuel shut off and increase. Check the fuel bowl to make sure the wires are properly plugged in. If so, it may be time to put a new solenoid on the fuel bowl. You can also check the float in the fuel bowl. They normally have a plastic float in there. The kit you can buy to replace the gaskets and the float has a brass float in it as an upgraded part.
Posted on Aug 27, 2010
Husqvarna hu725awd shutters and shuts off when blade handle engaged
Check under the deck make sure there's nothing holding the blades still. Check the belts make sure they are not in a bind. Also check the blade assemblies that they spin freely. If all of that checks out. I'll need a little more info to help you out.
Jul 20, 2016 | Husqvarna Garden
How to troubleshoot pto will bog down engine when you try to engage pto
when was air filter and fuel filter changed? are all pulleys turning free? spark plugs good? if everything seems good is motor wore out?
Sep 13, 2014 | Garden
Cub cadet 1554
Is there anything wound around the motor shaft? If its belt driven is the belt loose or tensioner bad?
Aug 15, 2014 | Garden
Poulan pro engine dies when blades are engaged
Something may be wrapped around the blade shaft under the mower deck or maybe the shaft bearings are bad.
Aug 10, 2014 | Poulan Garden
Electric clutch troubleshooting
Possible fuel mixture problem, caused by contaminated or wrong fuel. Carby may need to be cleaned and fuel changed.
Mar 30, 2014 | Garden
Kohler 22 bogs down when i engage blades on zero turn, cleaned carb did not fix.?
Check the plugs, if they are black and soot covered you may have a float valve that is not sealing allowing a little extra fuel to get into the mix. If you have the savy to remove and clean the carburetor then you should be able to replace the float valve, one tiny spec is all it takes and the float overfills; if you clamp the fuel line shut and the tractor improves after using up fuel in the carburetor it is very likely an overfilled float bowl.
Sep 19, 2012 | Garden
Why does engine speed decrease when blades are engaged?
need to clean grass from under mower change plug and air filter for better perfomance
Jun 15, 2012 | Garden
Boggs down when you hit grass a little high like its running out of gas 20hp on arens zero turn changed gas filter no help the gas filter does not show gas in it when running
This is usually indicative of strain on the motor, moreso than a lack of fuel. You may want to check and see if the blades are obstructed or the discharge chute may be blocked. Wet grass is a common culprit in this and can really labor the blades, as well as cake the deck making it difficult for the blades to not only turn and cut, but to discharge the clippings as well. As long as you have the 3 primary elements of combustion (air, fuel, fire), this is most likely going to be the cause of your problem.
Jul 30, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Mower boggs down when blades are engaged
If all pulleys are turning (not bound up) check for belt route misalignment.
Jun 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Jun 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
73 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
