Question about Danby DWC283BLS Wine Cooler
Compressor runs after set temperture is reached
Do you have any ideas about isolating this problem?
    Genius:
  • 3,422 Answers
HI,
I have been through your problem but i don't think there is any appropriate solution for this.All i can say it can be a bad compressor and you'll have to get it repaired.
Now just do one thing if you need other expert's advice on this then just rate me as thanx for trying in the premium problem whose solution you accepted as fixya.Your question will be reposted then so that other experts can give you advice.
Goodluck..
Posted on May 06, 2008
Hi. the compressors does not stop. Both chambers t-ra are OK. But compressor keeps running all night long even with no one touched or opened fridge. I believe the problem is with control box (white box at...
disconnect the temperature control setting and see if this kills the compressor as if the controls contacts are welded shut it cant open to stop the compressor when the temp reaches the set point of this control
Jul 06, 2011 | Whirlpool S20DRSS33 Side by Side...
High temperture
Have you check the thermostat?
You might want to remove it and install a new one see it still overheats.
May 27, 2008 | 2006 Chevrolet Cobalt
The a.c compressor works and the drier is sweating cold water outside the truck but HOT air comes out of the vents no matter the setting on the temperature control knob. Any ideas?
Make year and model engines size and country it was sold new in will help tell what kind of system you have, 60's modeels are different then 70's and so forth to the present. 90's and newer have electric air doors and it' possiblre that the cold air blend door motor is'nt working or stuck or fuse blowed. The blend door changes the temperture from hot to cold by dircting the air over the evaporater core or the heater core to get the dired temperture. Reaching up from under the dash with the truck running and the airconditioner on and the fan on ( not high) touch all the different motors till you find the one thats moving as you turn the control from hot to cold. if it's poping or grinding or you can't find any of them responding you need a new blend door motor. Working the other controls like the frst to reciculatre ( that motot will move as you turn this control on and off and the made door motor changes as you ask for defrost to floor to panel. The one that's not working needs changed. Most auto parts stores have them as they fail alot. thier les than 50 bucks some are as little as 25 but you did;nt state the year of your truck.
May 16, 2011 | Chevrolet C1500 Cars & Trucks
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
When i unplug and plug it back in then it run until it's get cold. And when it's get to the temperture i set. Then it's stop running?
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Asker's Testimonial " Very helpful. Will give it a try and let you know outcome. Thanks!!!
Apr 08, 2010 | Samsung RB2155SH Bottom Freezer...
Outside fan and compressor does not shut off
the system is wrong, the blower must run continuously , and the compressor is the will stop if the temperature setting is reached. The outside fan is the same as the comp.
Jun 16, 2009 | Heating & Cooling
Carrier PTAC Condenser ices over.
You are describing normal operation for a heat pump unit.
Feb 20, 2009 | Carrier 52CQ315 Air Conditioner
DE73 A04 Error code
you may have a bad heating element..or temperature sensor the water temperture is not getting hot enough to let the dishwasher run. you my reset it and try running the water in the sink until it reaches hot ... then try stating the dishwasher...let me know if this helps
Aug 28, 2007 | Indesit 24 in. DE73 Evolution...
Danby DWC283BLS Wine Cooler Logo
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
