Question about Haier Washing Machines
Hwm5tl im trying to find a manual for my machine it keeps displaing an e2 on the signal pad
  • 10,515 Answers
This is a common problem on Haier washer's. This problem is often associated with faulty or broken lid switch.Inspect and change the lid switch, if faulty.
If lid switch is fine, then we need to go with further troubleshooting.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 27, 2010
I JUST RECEIVED A BROTHER CX155LA, GOT IT THREADED AND IT WONT SEW A STITCH- KEEP GETTING E2
Search for:
Make Model E2 error
or check the owner's manual troubleshooting section
May 06, 2017 | Brother Sewing Machines
E2 error on a Samsung washing machine
The E2 error indicates a stuck or shorted key on the touch pad or a wiring problem between the touch pad and the main control board. Sometimes this can be cleared by unplugging the washer for 2-5 minutes. (Note: this is usually a temporary fix.) Next run your fingers across the keys. If you find one is lower than the others, that's the stuck key. Try to get it to move; sometimes just pressing it again will work.
You should check the wiring between the control board and the touch pad for any loose connections and for any corrosion or damaged insulation. Replace damaged wiring; reconnect loose wires. (To access this, unplug the washer and remove either the top or access panel at the back of the washer.)
If these don't help, you'll need to replace the touch pad or the control assembly (touch pad and control board). If you add a comment with the washer model, I may be able to supply the parts information for the unit. If your washer is under warranty, contact Samsung.
I hope this helps.
Jun 29, 2016 | Samsung Washing Machines
Code e2 appears on display screen
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
May 22, 2010 | Proform 730 Folding Treadmill Model...
The display code reads E2 and will not start
I just tried to find you a user manual, found that your machine is now owned by whirlpool, might be good to contact them www.whirlpool.com they have a customer help area and im sure they will help and with a manual etc
Jul 05, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Haier washing machine E2 error
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Sep 07, 2008 | Haier XQG50-11 Front Load Washer / Dryer
E2 error code
In reading the manual for this coffee pot, it needs to have the descaling procedure run. The manual lists running a mixture of 6 cups water and 6 cups vinegar in a normal brew cycle...twice to clean hard water deposits from the machine. It says to make sure to remove the filter basket. Once the procedure is complete, unplug the unit and replug in to remove the E2 code.
Jul 26, 2008 | KitchenAid Pro Line Coffeemaker Coffee...
Haier HWM5TL E2
I looked at the Haier website and all other usual sources but could find nothing. I think you should e-mail service@haier.com.au with the same query. Good luck
Sep 30, 2007 | Washing Machines
Washing Machines Logo
64 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
