Question about Danby DWM99W Top Load Washer
The water level will not stop filling up to the level desired. Washer will not drain out and then I need to empty it with a cup.
  • 905 Answers
Your water level sensor is likely faulty. Contact your retailer, or Danby directly, for a replacement and instructions on how to do so. Note, if this is in warranty, they may require you to bring it to a service center.
Posted on Aug 27, 2010
Lafw7000lw reviews
Good Afternoon Friend,
I understand that the fabric softener cup in your Frigidaire washer, model# LAFW7000LW, never drains and is filled with dirty water. This is a result of the siphoning action and is part of the normal operation of your washer. You may remove the water by removing the dispenser drawer and draining the water into the empty drum or sink. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Dishwashers
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
My Whirlpool Cabrio is so out of whack that it will not wash a single load without going of balance. I am generally a Mr Fixit, so with the help of some web advice I opened the top and I removed the wash...
yes the balance ring is supposed to be filled with glycol..... these washers cannot runn bulky loades or single articles of clothing.... if the load your running is not coating the drum evenly the all the weight is going to be on one side of the tub which is going to spin vigrously uneven,,,
also cabrio washer top lids are very slanted which means u cant level the washer by using the top of cabinet .... put level on each side use split of cabinet top to bottom of cabinet as your straight edge for placement of level ... theb level front to back and left to right and check other side ... if it checks out level....then take a clear cup fill 3/4 with water and place 2 feet infront of washer and start washer spin cycle if you see any ripples in water in cup while washer is spinning the reinforce floor joist under washer ...
Jan 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The machine fills and will not start agitating unless the lid is open and closed several times.
The most likely failure is the water level pressure switch or a failed lid switch. If the washer will drain and spin then it's not a failed lid switch. If it will not drain and spin the likely failure is the lid switch.
The water level switch (pressure switch) has 3 wires attached to it, V (violet), P (Pink) and a T (tan) wire. When the tub is empty of water, contact V&P are closed to allow the tub to fill with water. Once the water level reaches the desired setting, contact V&P opens and then contact V&T closes to start the motor agitating. So, with this said if you were to unplug the washer and remove the wires from the water level pressure switch and test to see if terminals V&T is closing by using an ohm meter would indicate if the contact is closed or not.
Jan 12, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Had blocked drain so water from sink backed up into d.washer. Drain clear but d.washer keeps emptying and won't fill
Make sure drain hose from dishwasher is higher than water inlet if not it will do just like a washing machine if the drain hose is lower than water level it will empty while filling.
Jan 19, 2010 | Dishwashers
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
WILL NOT STOP FILLING
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling the washer then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. This should solve your problem. Happy to help, Tim.
Jun 30, 2009 | GE WHRE5260E Top Load Washer
Washer won't stop filling with water.
There is a pressure switch with a tube to the water drain. The switch may be faulty or needs adjustment. The tube may be blocked or disconnected.
May 12, 2009 | Maytag LSE7806A Top Load Stacked...
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
The machine seems not to be working well
I had very similar problem and found the fix here.
Did you try the reset process? Place an empty cup, insert a coffe pod, press and keep pressing the "Lungo" button until the cup is filled as desired then release it. Next coffee, just press once, it should be now set at the desired level.
Jan 03, 2009 | Nespresso C100B Essenza Single-Serve...
Danby DWM99W Top Load Washer Logo
137 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Jim Y
Jim Y
Gerry Harvey
Gerry Harvey
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
