My LG LP1210BXR has stopped cooling. It works for about a minute then you can hear something turn off and then it blow warm air. I've tried it on every setting drained the evaloration tank ( which was empty) and cleaned the filter...... Please help Thank you !!!
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
  • 1632 Answers
SOURCE: why is my window unit just blowing warm air? the filter is clean,
Shut the lever to outside resiculation air.
Put the fan on slow,
Clean the filter and the temp probe in front of it
Vitally
Posted on Jun 02, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Posted on Jul 06, 2009
SOURCE: LG air conditioner model LG LP1210BXR
Well it needs to be fix by a professional, so if you or someone you know are good at tinkering go for it. It as a sensor problem at the evaporator.
Posted on Aug 03, 2010
heatman101
  • 43501 Answers
SOURCE: LG model LP1210BXR Water sprays
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 28, 2011
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
When I use the heating system it only blows warm air for about a minute, then it turns to cold air.
I think I would look to see if there is something restricting air flow such as an air filter. these units have electric heating elements to provide heat. There can be an over
temperature sensor that shuts the electric off . Without looking at the schematic diagram for it I can't provide much more. Also check the thermostat to see if it turns both directions. to the left would be cooler, to the right heat.
Jan 02, 2015 | LG "LT103HNR 10,000 BTU Through WaAir...
Indoor unit fan blows, then stops etc. every 1-2 minutes
At least it is cooling properly. U might just want to call Mitsubishi and ask them if it is operating normally based on your observations.
Apr 30, 2017 | Mitsubishi 18000 Btu Mr.slim Ductless Mini...
When AC on it is cool air for about a minute then goes to a slight warm air for five minutes, this jusst goes back a forth
Buy a AC recharge kit at your local automotive parts store and do it yourself or pay about $80 and have a shop do it so you have piece of mind.
Jul 06, 2014 | LG LP1210BXR Portable Air...
LG split unit AC works perfectly for 2 hours and then it stops blowing cool air
Check the amp draw on the condenser fan motor against the rating on the nameplate. motor may be getting weak and shuts down on thermal overload. If the amps are high you have a motor going bad, change it.
Aug 06, 2012 | LG Heating & Cooling
LG model LP1210BXR Water sprays out of air discharge while running in cool mode
heatman101
Aug 28, 2011 | Heating & Cooling
Jul 21, 2010 | LG Heating & Cooling
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
Heating & Cooling Logo
158 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
