Question about BonJour 1131044 Wine Cooler
The motor keeps kicking in and off - ir runs and then shuts off - then runs and shuts off - what is the problem?!
  • BonJour Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Model # UOBC-112QBGA The burner kicks on then the blower. After a few minutes the blower shuts off but the burner keeps running until it hits the high limit switch and shuts off
if when blower shuts off if still voltage to motor bad motor over heating if no voltage check board and safety circuit also see if overheating
Mar 22, 2018 | Heating & Cooling
Does this model shut off automatically when the desired room temperature is reached or does it function on a low medium high type of thermostat that continuously runs? IR 3 0 p m d g - 1
if it is an inverter type air conditioner ( make not indicated) the unit runs continually but the compressor delivery is reduced thereby reducing the load on the motor
as the room warms up again the compressor starts to pump more gas to keep the room at the desired temp setting
older types shut the compressor down and restarted when the high temp was reached
Jan 19, 2018 | Heating & Cooling
Yamaha V Star 1300 starts but immediately shuts down went put into gear with clutch in
clutch plates stuck keep motor off put in high gear like 4th and push back and forth till plates unstick make sure kick stand is up
Jul 19, 2014 | 2007 Yamaha V Star 1300
Heil nulk075dg05
You have a dirty or bad heat sensor. When you remove the front panel on you furnace you will see a probe that is 2 or 3 inches long that is in the flame when the furnace fires up. If it doesn't detect a certain temperature within the first 30 or 40 seconds it shuts down the furnace. You can either clean the probe off with sandpaper, or purchase a new one. They aren't very expensive and are easy to replace. In my experience it is usually a build up of carbon on the sensor and a good cleaning with sandpaper and alcohol usually takes care of the problem.
Feb 04, 2014 | Heating & Cooling
I have an IR Air Compressor #SS3 E. It want stop running/building up pressure. I am sure its the pressure relief valve, but there are 2. One at the presure regulator and the other at the pump and motor.How...
if it is lifting both valves I would say that the pressure switch (regulator as you call it) is defective, if you try to shut it off using the manual switch and it keeps running, I would say that the switch is welded shut. if it does not shut off by 125 psi then it is faulty. The pressure switch is what controls the motor in response to pressure in the tank.
Jan 31, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Rca rtd170 shuts off randomly except when IR eye on receiver is covered. When IR eye on receiver is covered, it runs for ever! No other remotes in vicinity (same room) as receiver. What could be...
Something else in the IR band is being interpreted as a turn off signal. If you directionally shield the IR eye you may be able to deduce from which direction it originates (keeping in mind that IR can bounce off of solid objects). Anything that emits might be doing it. Once you identify the direction you may figure out what it is and how to shield from it. I'm sure you'll figure it out.
Jan 27, 2010 | RCA RTD170 System
Dryer turns on runs awhile shuts off push knob again & buzz noise at motor push again & no noise or no dryer on , wait couple hrs. push knob, cycle starts over same result
the motor is defective starts runs overheats and kicks out on safety when it cool u can try again
i would check for something restricting the movement of the drumm as well a bad berring on rollers or broken or worn glides something in the blower area could give thge same results
try to open the door see if u can turn the drum freely
if u cant ( a compleate tear down is required to check for obstructions or worn parts if none found the motor ir the problem this should be done unplugged and buy a qualified repair man
(solv ya prob)
Oct 17, 2009 | Maytag Dryers
Air Ride Motor Keeps running
It could very well be separately fused; I'd check the fuse box first to see if one is marked for that feature.
Not sure about yours but typically self-leveling features stay active even with the ignition off and can kick in to adjust for in-or decreasing loads.
The Packards in So. Bend, IN used to often have run-down batteries thanks to the hoodlums I ran with.
Sep 19, 2008 | 1993 Cadillac DeVille
Fedders window air
Make sure the evaporator and condenser are clean. If so, is the blower motor still running when the compressor shuts off?
Aug 23, 2007 | Fedders X Chassis A3X05F2B Air Conditioner
BonJour 1131044 Wine Cooler Logo
42 people viewed this question
Top BonJour Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a BonJour Refrigerator Expert? Answer questions, earn points and help others
