Question about Motorola Mobility ROKR E6 Smartphone
Memory card is write protected
Hi frnds i purchased a E6 ,the problem is that when ever i take a photo it says ,file not to be saved,and always it says "memory card is write protected, for all applications,pls help me
i cant delete or save data on my memory card it says it is weite protected pls help me out
  • 13 more comments
  • Anonymous May 31, 2008
    whenever i insert memory card in my system. i get the message the card is write protected. please help me.
  • Anonymous Jun 02, 2008
  • buvanesh Jun 24, 2008
    hi... whenever i insert my card to PC using CARD READER..... i cant format the card and icant copy any files or songs from PC....
    some messge is coming ur memory card is write proteted how can i remove this .... plz help me....
  • Anonymous Jul 13, 2008
    hi frnds i purchased a E6 ,the problem is that when ever i take a photo it says ,file not to be saved,and always it says "memory card is write protected, for all applications,pls help me
  • Jagdish verma Sep 29, 2008
    im using Motorola E6 , im nt able to deleate any file from my memory card , it always show me an error " memory card is write protected "
  • cayl Oct 31, 2008
    hi, my cellphone is nokia 3230 and i can't store any files on my memory. how can i remove the write protected in my memory? plz help me...
  • lyka_11 Nov 15, 2008
    i cant add songs and images to my micro SD memory card..!!!!!!
    pls help me
  • muralihs1982 Dec 18, 2008
    Hi. I am having issues with my E6 memory card. It is a very wierd kind of problem. Even if the lock is in the 'free' mode the contents can be accessed from the phone, but not from the PC. I cant add anything or delete from the card. Tried everything. The biggest problem is that the card is perfectly ok when working on Vista but I cannot do anything with it on XP ! Somebody help...
    Murali
  • Anonymous Mar 05, 2009
    I have write-protected to memory card, I cont load any items in my memory-card. please solve my problem any?
  • Anonymous Mar 06, 2009
    when i insert my memory card,a message is displayed on my desktop.The message is "write-protected". What can i do, please tell me. i am in trouble,sir.
  • mhikshey Mar 11, 2009
    my memory card has no lock, it is a memory card of N70, i cnt find the sliding one to unlock.. what will i do? my memory card was write protected.. pls help mi,, badly need it asap.. tnx a lot godbless....
    -milka
  • Anonymous Mar 23, 2009
    my memory card keeps sayin uknown capacity and it wont allow me to format or download anything
  • nickydhacker Mar 23, 2009
    My memory card is write protected can anyone tell me how to get rid it off?
  • yhet08 May 02, 2009
    also same problem pls help us..
  • Anonymous May 07, 2009
    memory card write protected
You can see a tiny lock (kind of sliding button with the label ("lock") in memory card. Try it
-Saran
Posted on Jul 07, 2008
  • G saran Jul 07, 2008
    Take out your memory card and you can see a tiny lock button (kind of sliding switch labeled lock). you just unlock the card and use it. Hope this help for you.
    -Saran
I had the same problem with several cards but eventually found a way around it. DON'T buy a new one!
Make sure the SD card lock is 'off' and then use thin, opaque sticky tape (ie non see-through; eg insulation tape) to cover the whole gap but keep clear of the metal contacts at the back.
Your card should work fine now... don't know why this has to be done, but it works! Additional info: Reason #1, the mechanical lock switch accidentally moves to the "locked" position during insertion due to the poor quality of the switch. Hence, by taping it, you are actually preventing the lock switch to travel towards the lock position. i.e. downwards.
Posted on Oct 19, 2008
  • 3 Answers
Posted on Apr 09, 2009
Posted on Sep 14, 2009
Yup!! got the same problem..listen to all of ur good advice by 'unlocking' the tiny lock at the kingston adapter... works fine now!!
imagine my agony for weeks!!! hahahahaha...
stupid lock!!! i reformat my freaking card dudes!!!
Posted on May 11, 2009
Just take your Memory Card's Jack and see there is a TINY LOCK. If it is Locked then Unlock it and you will see the change.... Remember that it is for the problem which says " Memory Card Protected "..... I know this will help you
Posted on Mar 23, 2009
The problem isn't within ur memory card, but ur cards reader. Try to tight ur cable which is direct to ur
cards reader. Hope it could help u all
Posted on Nov 08, 2008
Re partition the card
Posted on Oct 17, 2008
  • 55 Answers
You might want to "format", or "fix" your memory card, these can have corrupt items on them.
To format the memory card:
  1. Press Menu (Center Select Key).
  2. Scroll to and select Settings.
  3. Scroll to and select Phone Status.
  4. Scroll to and select Storage Devices.
  5. Scroll to and select Memory Card.
  6. Press Menu.
    Note: If the memory card is not listed please remove and re-insert the memory card and restart Steps 1-5.
  7. Scroll to and select Format. The following message will display: "Formatting will erase all data. Continue?".
  8. Press Yes. The following message will display: "Format Complete. Enter New Label?".
  9. Press Yes and enter a desired label for the memory card.
    — or —
    Press No to use generic label.
Posted on May 07, 2008
Unable to delete the files from memory card
take out ur memory card from mobile slot, make unlock ur memorycard adapter. its on the side of it. and insert it and try deleting folder.
Oct 18, 2012 | Motorola Mobility ROKR E6 Smartphone
Problm with meu 850SW
You may try some recovery software to rescue the files on your sd card, here are some for your options.
Photo Video Recovery (for Windows)
Photo Video Recovery for Mac
Be careful: Before your files are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Jun 08, 2010 | Olympus ? 850 SW Digital Camera
How do we move the photos to the memory card in the camera?
Get out your manual and read the chapter about file transfers. It should be fairly simple to move the files from internal memory to external memory.
Aug 06, 2009 | Kodak EasyShare Z1275 Digital Camera
I have motorokr e6 and it has become write protected
in the left side of ur memory card there is a small button like thing u have to slide it down wen its up & slide it up wen its down
Jun 08, 2009 | Motorola Mobility ROKR E6 Smartphone
Write protection problem on Motorokr E6
Hello. I am having a peculiar problem with my memory card on my Motorokr E6. It always write protected even when the lock on the card is ''free.'' I can access it from a PC using windows Vista but cant add/delete content to card while using XP.
Dec 18, 2008 | Motorola Mobility MOTOROKR E6
Take your memory card out of the camera and switch the position of the little "lock" tab. That should fix it and you can start saving images.
Nov 10, 2008 | Nikon Coolpix L11 Digital Camera
Camera memory card - deleted dcim folder with antivirus
Try this..maybe work for you..cause it's work for me
in your explore click tools- folder options-view
check "show hidden files and folders" box and
"hide protected operating system files" box.
press ok. Your folder and picture will appears..
Cause in my case the virus change the folder into protected operating system files..
I hope will work for you too..good luck
Jul 10, 2008 | Electronics - Others
Try to lock down the little switch on the memory card.
good luck!
Dec 27, 2007 | Motorola Mobility ROKR E6 Smartphone
Motorola Mobility ROKR E6 Smartphone Logo
3,256 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
