Using TV as computer monitor
I have a Vizio tv with rgb connection and want to connect to my dell e1505 laptop. I have connected the rgb and also the audio to my headphone jack on the computer. TV says no signal. Are there setting to change in the laptop. Tv says "no rgb signal" and turns off?
  • 6 more comments
  • zanderluiz Sep 01, 2008
    My tv was working well with the rgb cable until the power on my hp laptop went out. Now the tv says no signal when I try to conect the laptop to it. I have a maxent plasma 50'' tv. Can you help solve this issue?
  • Anonymous Oct 16, 2008
    I have the same problem it keeps coming up with no signal even though it is connected properly
  • Anonymous Nov 11, 2008
    i have same problem
  • Anonymous Jan 01, 2009
    Same problem. The monitor cable seems to fit into the RGB input of the Vizio 37" HD LCD, but no signal.
  • Anonymous Jan 08, 2009
    I hooked my Vizio up to the computer and I get "No signal"
  • Anonymous Mar 28, 2009
    I have the same problem. The computer screen does not appear on tv when hooked up. I have rgb connection also.
  • msowers510 Apr 16, 2009
    I have this same problem!!!! please help
  • Anonymous Apr 28, 2009
    Ours did this at first, but we unhooked everything, found out we had a lose connection. Reconnected everything and now it works great except, after watching for about 20 min the laptop goes blank (even though there is no screensaver on) and you have to shake the mouse then it comes back. We have a vizio tv as well and a dell laptop
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
Posted on Oct 13, 2009
Just bought a vizio 42 inch 120hrts hd and trying to use my tv as a monitor i have a dell insperion notebook and im useing a rgb wire.. (bare with me im new to this haha) how do i get it too work =(
Posted on Sep 04, 2009
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.
Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
Oct 08, 2012 | IBM ThinkPad T40p 2373 Notebook
How to connect a laptop 3.5mm audio out to a Vizio soundbar
You need a 1/8" stereo jack to rca....can get on at walmart....hook it from your headphone jack on your pc to the input on the sound bar....input 1 or 2....make sure you have the right iput selected for the sound bar and you should be in business
Mar 10, 2012 | Vizio VSB210WS Soundbar
Where to connect my pen drive in my sony bravia lcd klv32s400a?
Hi Radhika,
Your TV has USB port on back side. Just plug your pendrive there. Then go menu on TV ( use your remote commander) and go to this input. Your TV will read the file on pendrive accordingly.
Regards
Oct 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Are you able to use the VIZIO 47" Class 1080p 480Hz SPS LED Backlit LCD HDTV as a computer monitor and use a wireless keyboard and mouse to browse on a pc through rgb and speaker jack?
Yes, all new TV's of 1080p specification will have a dedicated PC connection (and should have either a 3.5mm audio socket or 2 x RCA inputs for audio).
The most common way is to use a VGA lead (with 3.5mm audio lead) - VGA out of pc to VGA in of TV. 3.5mm audio output of pc (ie headphone socket) to 3.5mm audio input of TV.
You will just require the correct VGA lead long enough to connect to your pc.
The wireless keyboard and mouse will need to be connected to your pc, and must be within "line of sight" to the wireless receiver.
If you specifically want to use pc output to RGB input (and RCA audio in) of your TV, then you will need to obtain a long VGA to RGB conversion cable, plus 3.5mm audio lead. Have a look on Ebay for a coversion cable.
Cheers,
"Please take a moment to rate this solution with a 'testimonial' and/or 'thumbs up', as this will keep my status active and allow me to continue offering technical support. Thank you."
Jul 31, 2011 | Televison & Video
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Jun 10, 2011 | Acoustic Research AW-772 Headphones
How i am connect Wi Fi or internet to my TV.it is vizio and model number is J V 50 P HD TV 10 A. and Serial number is PHLANCJ2804679. I WANT CONECT WITH INTERNET FOR NETFLIX PLEASE LET ME WHAT CAN I DO.
As I type this, I am using my Vizio 50" plasma. All you need to do is ditch your current monitor you use for your internet service and use the same cord from the monitor to plug it into your RBG port on the back of your tv.
Next for sound there is a 1/4 jack next to the RGB port on your tv. Connect your tv to your audio out on your computer. (headphones or aud out)
Select RGB on your tv, and your good to go. I bought a wireless keyboard and mouse for my computer which makes it more convenient.
Apr 19, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
The vizio e322vl headphone jack is not documented by Visio. There is an "Audio" spot next to "RGB PC" and I tried various jack sizes b none works. If you have a soulution, can you...
that audio jack is input only it is stereo jack to connect from the comptuer to the tv when using the RGB input. most headphone jacks if they are there would be on the side of flat panel tvs. otherwise the audio output may be digital(optical) or normal rca (red and white) that you can hookup to the headphone system.
Dec 23, 2010 | Vizio E322VL 32 in. LCD TV
Connect and operate audio and video from Toshiba A215 4747 laptop PC to Vizio 32" TV for listening and watching internet on TV
Connect the Toshiba A215-S4747 to the Vizio TV by using either the Standard RGB (monitor out) port or the S-Video out. Use the headphone output port for the audio.
Jan 27, 2010 | Computers & Internet
Hello, Currently I have Vaio laptop connected to my Vizio 42" inch flat screen TV. There's no audio coming from my Vizio TV. So I connected an audio cable connected to the stereo jack. Where do I connect...
You need a 1/8 in cord on both ends. Normally, its an 1/8 inch audio connection in your tv to work with PC (the same connection as when you plug it in your comp) So u would need a wire that both ends are 1/8 inch (Headphone jack sized)
Sep 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
3,014 people viewed this question
Top Televison & Video Experts
Electro Med Services...
