Question about Kenmore Grilling
Even after I change the propane tank, the burners only produce a small flame. If I turn all 5 burners on, the grill doesn't get very hot (about 200), so I had to cook on 2 grills and the temperature only got to 300.
  • 10,865 Answers
Hello John. The problem you are experiencing is due to the new and "improved" safety valve on these propane tanks. Do this.
Unscrew the tank from the grill hose. Then reinstall the tank but this time open up the valve v-e-r-y slowly. This should prevent the safety valve from sensing that you have a leak and partially shutting off itself. J.
Posted on Aug 27, 2010
Grill troubleshooting
It's not getting hot enough.Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 31, 2014 | Holland Grill Classic II (NG)
Poor flame after changing tank on gas grille
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
I can light one burner to produce low flame only. Propane flow does not allow for both burners to produce flame at the same time. After one burner is lit when I attempt to light the second it will kill the...
Mike, your gas regulator is locked up. To solve the problem, do the following.
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow) until the valve is fully open.
4. Light on burner and turn it to HIGH. Does the flame height look correct? If so, light the other
burner the exact same way. Do both flame heights look correct? If so, you solved the problem.
In the future, always remember to turn the tank valve ON very, very slowly.
If the above didn't solve the problem. You will need to replace the grill's Hose/Regulator Assembly. You can pick one up from any hardware store or home center that sells gas grills & accessories for about $30.00. Take you old one with you for comparison purposes.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Jun 30, 2011 | Thermos Grill2Go Gas Grill 4656110
I have a Weber gas grill, and I just replaced the propane tank, yet when I ignite it on the Start/High setting, very little flame is produced. This is the first time in 5 years or so that I've...
Don't worry, you'll be grilling in no time, if you follow these instructions:
1. Turn the gas tank valve OFF.
2. Disconnect the grill's hose from the propane tank and wait 5 minutes.
3. Reconnect the hose to the tank and open the tank's gas valve VERY, VERY SLOWLY (Slow Motion, slow).
Once the valve is fully open light one burner and turn it to HIGH. Has the flame height returned to normal? If so, light the remaining burner and turn it to HIGH. Do both flame heights look normal?
If so, you solve the problem! Remember to always turn the tank valve ON Very, Very Slowly.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 16, 2011 | Weber Baby Q Grill
I bought the Brinkmann 5-Burner Grill Model 810-9520 a little under a year ago and recently have been having problems with the flame. The grill will lite with a strong flame if just one burner is on, but...
hello megan. actually the propane tank is causing this problem. the newer propane tanks have a safety feature built into them to prevent fires and explosions. that is a good thing. what is not so good is that the tanks are now a wee bit tempermental. this is what you now need to do. turn off the tank and unscrew the hose. let the hose sit unattached to the tank for 5 minutes then hook it back up and very s-l-o-w-l-y turn on the gas. That should solve the problem. if it doesn't repeat the procedure. joe
May 24, 2011 | Kitchen Ranges
I just purchased a brand new tank of propane and i still have the same problem that the propane burns out of all 4 burners but at a really low flame even on high. I can not get the grill to heat up...
Turn the tank off. Disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the LP tank valve on VERY, VERY SLOWLY until it's fully open. Now, light each burner one at a time and turn it up to the highest setting. If that didn't solve the problem, repeat the previously listed steps.
If after the second attempt the burners still only maintain a low flame, you will need to replace the grill hose/regulator.
Hope this solved your problem and Happy Grilling!
Feb 27, 2011 | Brinkmann Charmglow Stainless Steel LP...
I replaced the burners under the grill and the gas is is flowing with a very small flame but i cant get it to have a large flame. what can i do?
Easy solution. Turn off your propane grill tank. Disconnect the hose from the tank, Wait 5 minutes and reconnect the hose. Now, turn the tank vale on very, very slowly, until it full open. Then light each burner one at a time. Turn the flames to high.The burner flame height should have returned to normal.
Remember to turn the tank on very, very slowly each time after turning the tank off.
Happy Grilling!
Feb 11, 2011 | Ducane 30400040 Stainless Steel Grill
I can not get any gas pressure in main burners or side burner, i have a new propane tank, just a trickle of gas not even enough to keep side burner going when only using side burner, will only produce a...
Look for spider webs in the venturi tubes, check the orfices or it could be faulty controls. Verify the tank working properly by trying on another grill.
Eric
Jan 24, 2010 | Brinkmann Charmglow 810-7400-S Propane...
The flame coming out of the burner bars is small
May likely be low on propane or propane tank gate valve not opened far enough. Otherwise sounds like faulty regulator.
Jan 16, 2010 | Weber Genesis Silver A Grill
Genesis s310 stainless grill. Does not fully light.
Regulator is not bad, as I stated before new valves are designed to reduce gas flow if valve is opened to fast. This is so if grill catches on fire, the tank will shut itself off, thus propane will stop flowing causing fire to extinguish itself.
Dec 28, 2009 | Weber Genesis E-310 Gas Grill
Grilling Logo
76 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
