Question about Whirlpool Dryers
Hi-my dryer is working but is making a scraping noise when it rotates. At first I thought it was a zipper but it is internal.
Sounds like it might be the drum bearing going bad causing the drum to tilt. My buddy had the same problem and his was so bad it wore through the edge of the door. I'm no tech so wait and see if someone else chimes in on your problem. It could be something simple too.
Posted on Aug 27, 2010
G e profile dryer makes scraping noise while rotating clockwise
your top door bearing and glides are worn out,remove 4 top control,panel torx screws,then open door and on the top of the door land are 2 screws holding the top panel,remove these,then push top to the left or right to remove from the catches at the back,then unplug door switch and light wires from door to unit on lower left side,lay door on smooth surface and un clip top door bearing,replace worn out bearing along with white and/or green glides,whatever unit calls for,some use only white and some use white and green glides
Mar 11, 2012 | General Electric DCVH680EJWW Dryer
Dryer works, but makes noise.
There are a lot of moving part that can cause noises or vibration when get worn out.
  • Make sure dryer is level, and on a secure floor, and that nothing is leaning against the dryer.
  • Check all exposed screws, and make sure they are tight. Loose cabinet screws may cause a squeak.
  • Check for foreign objects below the lint filter:-Remove lint filter, and look down opening. If you need to stick your hand down the opening to remove an object, be careful because the edges could be sharp. It would be advisable for you to wear a pair of work gloves.
  • Foreign objects in the drum front seal and worn or loose drum slides can cause a metal scraping noise as the drum rotates.
  • Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
  • A frayed or damaged belt will make a thumping sound.
It is normal to hear the sound of the drum as it turns. If your dryer is making unusual noises and the above suggestions do not resolve the situation, discontinue use of the dryer until it has been checked by a qualified servicer. Continued use may cause wear of other parts making the repair more costly.
Thanks..!!
Sep 19, 2010 | Kenmore Elite HE4 Electric Dryer
Hi, Thee dryer makes a loud noise during cycle. It starts low, but it seems after each rotation it get louder. Has anyone ever experienced this and are there any solutions. Thanks for any assistance.
Describe the noise. If its a rattling banging noise you could have a broken exhaust fan which is usually attached to the motor, a broken cylinder roller (if your dryer has them) or worn felts. Maybe a noisy pulley. If its more a high pitched squeek it could be your motor or the parts just mentioned. A metal scraping noise could be something like a bra wire caught by the cylinder but I don't see how that can get louder as the rotates. Make sure the belt isn't cracked all over. Worst case scenario is that your motor is on its way out...
Good luck
Aug 29, 2010 | Dryers
I cleaned out my lint tray and after I put it back in, the dryer started making a grinding noise?
May be loose drum slides can cause a metal scraping noise as the drum rotates. For that you'll need to contact Crosley Service Center.
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 02, 2010 | Crosley CDE6000 Electric Dryer
My dryer makes a scraping noise when the bowl
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
You may have two problems:
1...The felt seal around the door is faulty,broken, or out of place.This will cause the problem of zippers,buttons, etc. to get caught between the door and the drum
2...Drum rollers, this causes squeaks,and thump type of noises.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication and the felt seal between the door and drum maybe faulty.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt,and felt seal.
Check your felt seal at this time to see if you can reinstall it or you may have to replace it.
Remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise and the problem of getting clothes caught in between the door and drum.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 29, 2009 | Frigidaire Dryers
Dryer making squeeking noise
Check the dryer belt tensioner and pulley assembly. It be wearing out. You'll need to remove the back cover of the dryer to do this. Turn off the gas and/or electric before working on the unit.
Mar 26, 2009 | Maytag MDE9316 Dryer
Drum Noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hjdj
Feb 22, 2009 | Kenmore Elite HE4 Electric Dryer
Maytag dryer making clanking noise
I had this problem and the cause was a loose screw holding on one of the "paddles" inside the drum. I removed the door, front panel, lifted the top, manually rotated the drum until I saw the screw head which had worked loose and was slapping the side of the dryer. A quick tighten of the screw and the noise was gone.
Jan 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool Duet Sport Gas Dryer - Works fine but makes loud noise
heatman101
yriur
Nov 24, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
