Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
Dishwasher will not run and its showing a code of tE. Any idea what the problem might be ?
  • 10,865 Answers
The thermistor is located between the terminals of the heater and comes as part of the heater assembly. You will need to pull out the entire dishwasher to replace it. The heater assy is stuck into the side of the sump,you can access it from the bottom of the d/w once ou have it out. The only source of parts in the US I know of is LG in Huntsville AL.
Posted on Aug 27, 2010
What does code F2E2 mean on the display
My Kenmore Elite dishwasher is showing code F2E2..What ...
www.shopyourway.com > Agafia Reutov > Questions
The F2E2 error can be frustrating. The problem is the User Interface is not communicating with the main control board. This error is mainly caused by a poor ...
Kenmore elite service code f2e2 ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Te hose came off the bottom of the washer, then I got the service code f2e2. ... I have a kenmore elite dishwasher model 665.1396 ERROR CODE F2E2 ?
Oct 22, 2015 | Dishwashers
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
I get a te code all the time and a he code from time to time.
from Lg this is the meaning of the codes.
  • The heater circuit has failed if "HE" is displayed. Discontinue use and contact a service technician. The dishwasher requires servicing.
TE
  • "TE" means the thermistor has failed or the temperature of the water entering the dishwasher is over 194 degrees Fahrenheit. Turn the temperature down on the hot water heater in the home. If the error code reappears, replace the thermistor.
    By the sound of this your heating system is malfunctioning and needs service.
    If you need more on this let me know, but it is either your temperature sensor or your heating element or control board.
Oct 02, 2011 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher LDF modle 7811st error code tE just gives erroe code will not start.
TE error code means Thermistor Fault or Inlet Water Temp too High.
Check the resistance of the thermistor (located on the bottom of the unit in between 2 orange wires with single spade connectors which is the heating element) and it was good 11.7K ohms at 71 degrees room temp. Take the front door off and trace wiring. There is a white plastic wire loom and approx.6" up check the wiring being melted in the black mastic. The thermistor wiring is red and dark blue.
Generally, some lose or broken wires cause this. Keep us updated.
Jun 27, 2011 | LG LDF6810ST Stainless Steel Built-in...
LG DISHWASHER TE ERROR CODE
you have 1 of 3 problems...the water is to hot over 140 degrees..your thermister went open,,or you have a bad pc board,,(control) onthejob
Feb 04, 2009 | LG LDF6810ST Stainless Steel Built-in...
Hi there I have a silver LG dishwasher..I am intermittentleey getting the Code PE. I have take the pump off the exit water pipe and chaeck for blockages etc... there are none. Any ideas?
Please confirm the model number of this LG diswasher.
On recent LG units, the avaiable error codes are: IE OE E1 FE tE LE
The PE code is abnormal. Can you confirm.
I would expect to see the error OE if water is not fully pumped out. Remove the filter from the sump area beneath the bottom rack. Look closely for debris causing a blockage/lock. Please get back to me with your findings and ask more questions as needed.
Jan 25, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
TE Code flashing what do this mean?
Error code tE is THERMAL ERROR. It is possible that the thermister has failed, but the most common cause is inlet water being hotter than 149 degrees (F) The optimal inlet temperature is 120 degrees minimum.
Always check that before you suspect hardware failure.
What did you find to be the problem? Thank for a reply.
Dec 23, 2008 | LG 24 in. LDF 7811 Stainless Steel...
ERROR CODE "TE"
The MOSt common reason for a "tE" error code is the temperature of the hot water from the hot water heater is greater thant 145 degrees (F)
Adjust your hot water heater down and measure the temp at the kictchen tap.
Good Luck!
Aug 26, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Lg dishwasher trouble codes how to clear
my LG dishwasher error code TE and won't start- can you tell me what the problem is?
Jun 30, 2008 | Dishwashers
DE73 A04 Error code
you may have a bad heating element..or temperature sensor the water temperture is not getting hot enough to let the dishwasher run. you my reset it and try running the water in the sink until it reaches hot ... then try stating the dishwasher...let me know if this helps
Aug 28, 2007 | Indesit 24 in. DE73 Evolution...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
78 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
