Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No sound or picture--When turning on, it goes into Standby mode. The standby RED mode light is Blinking 10 times, goes off then starts Blinking again 10 times then goes off!!
  • rcd84 Aug 27, 2010
    What is a power supply module & where is it located ??
  • Sony Master
  • 6,993 Answers
your TV is having a power problem. The power supply board is defective that's why the TV is blinking and won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty on the power board. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
Take care.
Posted on Aug 27, 2010
  • Walesarumi
    Walesarumi Aug 27, 2010
    you can trace the power supply board or power module from the AC outlet wire (the wire that comes out of the TV to the wall).
    Trace the wire back into the TV and you will find the power board. The AC wire is soldered to the power supply board/module.
    I hope you understand this.
    Good luck.
    Novelist:
  • 132 Answers
I would start by looking at the power supply board to see if there are any electrolytic capacitors that are domed or bulged at the top rather than flat. If any of the are bulged then replace any of those. If you can't do that or if they all look ok, then you can just replace the entire power board for under $100 if you do it yourself. you can get them on ebay at this link...
http://shop.ebay.com/i.html?_nkw=KDL-40S2000+power&_sacat=0&_odkw=KDL-40S2000&_osacat=0&bkBtn=&_trksid=p3286.m270.l1313
This isn't a guarantee that it's definately on the power supply, but definately the first place I would start if I were working on this set. Without doing a lot of tests and checking several components w/ a meter, there's no way I can tell you for sure, but w/ my experience I'd say it's about a 75% chance that a new power supply module will fix it. Our shop would probably get around $250-$300 for this repair, and most others will be about the same.
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
Sony wega kdl-l32mrx1 10 yrs old. picture wont come on display standby light goes green then a crackling sound from the back of the tv, the standby light then goes red again, and flashes 6 times have
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 16, 2014 | Sony WEGA KDL-32XBR950 32 in. LCD HDTV
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Was watching TV, heard a pop and the screeen went black. Now when I turn it on, the pwoer light blinks green but their is no picture or audio. The light then starts blinking red
Is is standby light blinking red or any other light? Let me know how many times red standby light blinking after three seconds long pause to provide you helpful info.
It seems pop sound was due to broken lamp, please check lamp inside tv and if it is broken, replace it to solve tv problem.
Hope this will help.
Thanks.
Mar 09, 2011 | Sony KDS-50A2020 Television
Hi- we are having a problem with our ps3....it just started overheating....we forgot to open the door...I heard the fan kick in...so we turned off the ps3 to let it cool down....now the ps3 is running...we...
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
When i on the tv by remote the red standby light turns into green and i hear the tv sound but not picture and after a one or two second the green light turns into red. The tv goes into standby mode when i...
the high voltage or flyback transformer is not working.the sound runs off a separate fixed power supply.if you run your hand across the screen,is there static?that would mean the high voltage is ok but there is another circuit fault
Jul 08, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
Mar 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Slow record time/goes into standby mode
It sounds as if it is working mechanically, but there is a software fault.
Try downloading a new driver for it (or use the CD which you may still have)
They are available free Here.
(Please contact again if this does not solve the issue; If it does, Please rata as Fixya! so others may benefit. Thanks.)
Feb 16, 2008 | Nikon Coolpix 5600 Digital Camera
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
52 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
