Question about HP Compaq dc5100 Microtower PC Desktop
I have no ethernet driver for my modem. This is strange because I didn't install anything new. Where can I get my driver?
    Sergeant:
  • 235 Answers
First, check yoour computer for virus, spyware, malware, etc. Then, go to www.hp.com and go to support, drivers and downloads and download it. If your computer does not connect to the internet, use a friends computer or go to the library and download the drivers on to a flash disk. Have fun!
Posted on Aug 27, 2010
How to install huawei ETS1001 (FWT) modem driver for windows 7 OS
Windows 7 should manually install the drivers for the modem. However, modems usually don't require drivers unless they're being plugged in with a usb cable. If possible, I would use the ethernet connection as it's much faster than the usb connection. If that's not possible, search on the manufacturer's website to find the driver you require. I did some searching myself and couldn't find anything specifically relating to Windows 7, but usually a Windows Vista driver will work.
Mar 05, 2011 | Computers & Internet
I lost the disk for the RCA DCM425 digital cable modem the cable company gave me. how can i get the modem to work on my new computer?
Hello Friend,
If you didn't change anything in modem side, that means the modem is still connected to internet. in this case you can connect the modem to your computer via the Ethernet cable. with this cable you will not need to install anything on your computer, just plug the Ethernet cable to the RJ45 port and start browsing internet.
The only case when you will need the drivers is when you want to connect the modem to your PC via USB cable.
Here is a link where you can find everything about your modem: quick guide, user manual, usb drivers ...
Best Regards,
Oct 30, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Ethernet light went off and won't come back on on dsl modem
no matter what the model is, the thing has to work. it is not that ur new modem is smaller so it is not working . Check the suggestable router modems for AT&T . if ur modem is working fine , then install the modem drivers in your Pc.
Aug 21, 2009 | Computers & Internet
No Wireless/ wi-fi
did you install the modem driver aswell? the modem and WiFi wireless is a mixed unit, as need both drivers to funktion.
/Teis
Jan 03, 2009 | ASUS Z83V Notebook
Toshiba Cable Modem PCX1100u
OK. First of all you do not need a special or seperate driver for the Ethernet port. Its factory loaded with your OS.
All you need to do is plug the Ethernet cable into the LAN port on your HP Desktop and then into the LAN port (not the WAN port) of your cable modem.
The second thing is if its only a cable modem, then I suggest you proceed with caution as there is NO built-in firewall on a cable modem. Yes you will get on the net, but you are likely to be attacked with virus the moment you connect. I suggest you check very carefully whether the cable modem (if that's what it is) does/does not have a firewall as you would be very unwise connecting up like that.
Next, forget USB connection to the router/cable modem. That technolgy we've moved on from.. Your Vista shodul be 'plug n play' adn should configure the router for you. obviously that bit isn't so slick on yours.
Let me know how you get on..
Aug 31, 2008 | Toshiba PCX1100U High Speed Cable Modem
Install
If the modem is already registered to your ISP then you can plug the modem to your computer using an Ethernet cable (CAT5) to your computer's ethernet port and to the modem's port as well.
If you want to use the USB cable then you need to install the drivers for it. You may go to motorola website and type in the model number of your modem to get and download the drivers.
Though, I suggest that you use the Ethernet connection instead.
Aug 02, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Installing a internet modem
you open case
have comp turned completly off
install ethernet card into proper slot screw down
turn on comp goto control panel network setup wizard follow instructions from there
remember first your modem has to be recognized by your service provider first before you can get that connection and they give you the service to connect
say like cox qwest or other service provider
May 09, 2008 | Dell Inspiron 5100 Notebook
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
HP Compaq dc5100 Microtower PC Desktop Logo
35 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
