Washing Machine faulty
In last washing my Indesit 1263WG throw some black mechanical greas onto the clothes and there are some rubber bits left in the drum as well. Machine can spin and drain, but there are water can out slowly. Which part of the machine could be broken?
Water in drum after washing
Posted on May 13, 2008
Need Service Manual (*Not* User Manual)
My best advice: contact INDESIT
http://www.indesit.co.uk/indesit/entryPoint.do
You can contact CONSUMER SERVICE through this webpage:
http://www.indesit.co.uk/appliances_i/contact.do
In pages 15 & 16 of user's maual you can find phone contact numers so you can ask manufacturer about getting a service manual
You don't have the manual?
http://www.indesit.co.uk/indesit/_pdf/manuals/19504297004_UK
Aditionally, it might help you how to put clothes in your washing machine.
Sep 03, 2015 | Washing Machines
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
THE INNER DRUM IS BAD WITCH LETS IT RUB THE FRONT SEAL OF THE WASHER YOU NEED TO SEE IF YOU CAN MOVE THE DRUM UP ARE DOWN ARE SIDE TO SIDE IF SO ONE OF THE SUPPORTS ON THE BACK BROKE AND THE GET THE SMELL OUT WASH THEM IN WHITE VINAGER
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Indesit WG1234T - is there a filter and spin cycle not effective
If there is no filter located at the bottom right front of washer behind a re- moveable cover, then you need to remove the rear cover of washer.
Locate and remove the large black hose fastened to bottom of drum.
This should help solve your prob.
Jan 05, 2010 | Indesit W 123 Front Load Washer
Indesit wd1030 washing machine drum not working
Your drive belt may be damaged and needs replacing
Nov 06, 2009 | Washing Machines
Black marks all over the rubber seal at the front of machine.
The mould you are referrng to is actually bacteria that is building up because you are doing too many low temp washes.
What you must do is a high temp wash periodically,with powder in but no washing.
Do this 3 or 4 times a year, more if you do a lot of wahing.
It is called a maintenance wash, and helps kill off the bacteria.
With a scouring pad or steel wool pad, clean as much scum as you can off the door seal. particularly in the folds of the seal.
You will probably be left with stains in the rubber, but as long as you have got the worst off, it should be o/k.
Please rate my solution.
Thanks.
Jan 21, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Some of my clothes are coming out of the dryer with black streaks in different places, sometimes i can see that a corner of a tea towel or similar has got stuck in the rim and wondered if this is causing...
Does the temeperature appear to higher than usual?
Does the dum spin correctly (smoothly and at a constant speed)?
I am thinking that the rubber belt that spins the drum may be getting hot somehow and melting bits in the dryer holes of the drum.
Is the drum stainless steel or painted?
There are generally no other components that can come in contact with the contents of the clothing.
The only last thing I can think of is whether a piece of dark clothing (i.e a sock) has queezed behind the drum and moisture is picking up the colour.
Sep 16, 2008 | Dryers
Re washing and drying
Hours? It sounds like your machine has a problem.. Have you tried clearing the filter on the outlet after the drainage pump? The Indesit only has a 1200 spin speed so it's not the most efficient drier anyway (rated B for spin efficiency).
Personally I dislike Indesit as they release some models which do not permit replacement of the bearings because the innner and outer drum assembly are crimped/pressed together during manufacture. Instead of replacing bearings and seals (At most about £35.00) you would need top buy a complete drum assembly at about £125.00, and throw away a large lump f stainless steel. Presumably Indesit want you to throw the entire machine away, and to buy a new one. Not a brilliant idea in my opinion, as it is unlikely that a frustrated ex Indesit owner will but an Indesit as a replacement, and that sort of wastage (bearings last around three years in regular family use) makes a complete nonsense of energy efficiency ratings. The cost of manufacture and disposal over a three year usage period will have a massive carbon impact in comparison to the energy efficiency savings even of the most efficient of machines.
The planet can't afford to buy cheap machines and then thropw them away.
Apr 28, 2008 | Indesit W 123 Front Load Washer
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
