Question about Hayward SAND FILTER, PRO SERIES
I have a 3/4 hp superpump that is about 2 mos old. when it runs it "Surges" and puts out no pressure. The suction line is drawing in water.
  • 4,070 Answers
I had a problem with mine. It also was drawing in water but it turned out it wasn't enough. The flap on the skimmer wasn't opening all the way. It get stuck closed sometimes. I probably need to sand on the hinges a little.
Posted on Aug 27, 2010
Operation pressure
suction pressure should be about -4 inches of mercury and discharge pressure should be around a hundred and fifty. do not put the gauges on to the suction line while is running or you will draw air into the sealed system. attach a gauge is only when the unit is off and equalized
Appliance 911 Sea Breeze
Sep 30, 2015 | Metalfrio PICL3-92-12 Pizza Prep Table...
How do I stop my swimming pool from leaking water?
id look 4 a leak someplace in the suction side of things when pump runs it draws air in hole so No leak but when pump shuts off No draw just water and it leaks out
look for hairline cracks in skimmer bottom and bottom suction lines , Might require scuwba equipent to see ?
Nov 03, 2014 | Pool & Spa
My new Optiflow pump surges..............it seems to not be pulling the water thru the sand filter and discharging as it should. Sand filter gauge fluxuates between 0 and 3 lbs of pressure.
it sounds like you may have a suction side leak on the pump. check the lid o-ring and the suction side fittings to see if there may be a possibility of air being sucked into the pump and causing it to act like it's picking up prime and then losing it.
Jul 25, 2011 | Pentair OptiFlo Aboveground Pool Pump 1 HP...
I have a model 109163. I'm trying to pump water from a creek. The suction hose is about 6 ft below the pump and 12ft long. The output hose is running about 300 ft at a gradual incline to about 10 ft. My...
In order for the pump to **** up water, it must discharge air. Try this. Install a hose bibb (faucet) in the discharge line over top of the pump. Fill the pump housing with water, turn on the pump and open the hose bibb/faucet until full water flow is established. Almost all air should be out of the pump and suction line at this time. Now when you close the hose bibb/faucet, the pump will have plenty of pressure to fill the long discharge line.
Suction line should be 2-1/2 inch if that is the pump suction size.
What size is your discharge line?
There should be a check valve/foot valve on the end of the line in the creek to keep water in the pump once it is primed.
Gary
Dec 19, 2010 | Hayward 1.5 Hp Northstar High Performance...
Hi i have a k3.65 jubilee model when switched on it constantly surges and the water pressure is not as good as it was its only 10 months old.any advice
Have the hose pipe running into a bucket/container and use another short length of hose from the pressure washer to **** the water out of the bucket, that way if the bucket is full when you start, any drops in mains pressure wont affect the pressure washer as their should always be a reservoir or water to keep constant pressure.( you may need to prime the suction hose first, just hold the 2 hoses together in the bucket of water with pressure washer on)
Any questions ask
If this helps please rate me
Oct 19, 2010 | Karcher Garden
I have 1 and 1/2 horsepower sprinkler pump that wont prime. As soon as the end piece fills, it will empty if I open the end to the sprinkler.
I don't know what is your system set up. However, the system set up should be the following;
1. Your 1-1/2HP sprinkler pump must be installed at
a fix location nearest the water source. (Complete
with power and plumbing lines.)
2. At the end of the suction line is a vertical check
valve with strainer.
3. The suction pipeline must be connected to the
suction port of the pump.
4. At the discharge port, a flow control valve tee must
be installed. The flow control valve tee top is
covered with a plug, which serves as the priming
port when opened.
5. After the flow control valve, connect a short nipple
so that you can put a gate valve to stop the water
flow or allow the water to flow. You may connect
a pressure tank at this point or you may connect
the pressure hose going to the sprinkler.
6. To prime the pump, open the plug at the flow
control top. Fill it full with water, replace the
priming port plug.
7. Turn the flow control valve to full closed position.
8. From full close position, switch the power on.
9. The pump now run on and off due the pressure
switch setting. Slowly open the flow control valve
such that the water pressure remains steady.
10. Take note of the pressure.
11. Shut the power off, and connect the sprinkler
pump hose.
12. Put the power back on, and allow the pump to
run with the sprinkler.
Under this set up, you can run the sprinklers when your pump is running. Hope this will solve problem.
Dec 08, 2009 | Plumbing
I am replacing my Hayward 1 HP superpump. The old pump had the 230/115 conversion plug on line 1. The new pump has it on line 2. Do I jusst connect the 115 v(hot) wire to line 2? That would be oppisite of...
It will not matter where you put the hot and neautral as long as one goes on line 1 and the other on line 2. Just be sure to reset the voltage indicator to read the 115V like before and your all set.
Oct 19, 2009 | Hayward 1.5hp 230v 2 Speed Uprated Super...
I got 1 year old flotec 3/4 hp pump and it take
I have had the same problem there are a few things that can cause it to take longer to shut off, if you are running a sand point well that's usually a sign that the sand point is clogging up,if you have a sistern or a dug well check the screen on the end of the suction pipe,another possible cause is the water level has dropped low enough the pump is having to work harder to pull the water up, you should also check your pressure tank and the points for the pump if the points are sticking the pump will keep running till it builds enough pressure to trip them.Check for leaks in the suction line, if it is sucking air that would cause it to run longer to.I hope these suggestions will help fix the problem. Have a great weekend
Sep 05, 2009 | Flotec Plumbing
I'm need assistance wiring my hayward 2 speed super pump up with my pool timer. the pump is working now but it's running real hot and making alot of noise.
You may have a faulty bearing ... causing the noise. The pump is actually water cooled. Do you have 2 inch line for your 2 HP pump? Small pipe makes the pump work harder. If your lines are smaller, you may want to consider a smaller pump.
the motors will run pretty warm.
Run your pump on high for best results.
If you are using a timer ... you will need a double pole switch to turn it off if it is setup for 220 VAC (which it should be, for most econimical operation)
Jul 08, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Hayward SAND FILTER, PRO SERIES Logo
74 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
