Question about Mitsubishi Heating & Cooling
Do the older mr. slims have the metering device located in the evaporator
  • 455 Answers
YES
Posted on Aug 27, 2010
MITSUBISHI ELECTRIC MR. SLIME MSHO9TW REMOTE CONTROL MANUAL
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Jun 03, 2014 | Mitsubishi Televison & Video
P8 showing on air cond and air con is not working
P8-Abnormality in outdoor unit.
Solution:
1) Check the indoor/outdoor connecting wire in proper point.
2) Change the connection of electric wiring, if reversed phase.
3) Check the protection device, if malfunction, replace it.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Thanks.
Feb 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I need an evaporator control board for Mr. Slim Model MS 18 NN Where can I order this item ? Please help. C.J. Leslie
Here you go
http://www.expertappliance.com/mitsubishi-mr-slim-parts.html
Here is a tip that wrote about how to buy heating and air conditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Jan 28, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Pressure readings
the metering device is in the outside unit on mini splits that is why the liquid line sweats. pressure reading depend on load high load high readings i would shoot for arount a 40f suction saturation temp
Jun 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr slim Mitsubishi - how much fill
On the data plate for the outdoor unit it will tell you what type and how much refrigerant you need. If the line set is longer than 25 feet you will likely need a bit more than what it says. A 40 degrees evaporator temperature is ideal, approximately 65 psi for r22
Mar 31, 2017 | Mitsubishi Mr. Slim MXZ30TN Air...
Ice forming on front coil of aircon blower
the front coil or evaporator is not absorbing heat from the conditioned space or the condensing coil or back one is not rejecting heat. usually this is due to dirty coils or clogged filters
Nov 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr Slim mini split outdoor unit fan.
Check the capacitor. Rating must be within 90% of rated microfarads. If it is a dual capacitor test between C and FAN. Set your meter to read microfarads (uF).
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
No heating from Mr slim
P8 refers to outdoor protection device activation usually caused by low gas charge or blocked condenser coil. any good a/c company can resolve this for you. however please note that if it is gas related a pressure test must be carried out to determine where that potential leak may be and that can be very costly.
regards
Ed
Nov 13, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Open Questions:
Heating & Cooling Logo
21 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
