Question about LG Dishwashers
LG LDF 7920 dishwasher worked fine for 1.5 years. Now doesn't dry - I suspect heater doesn't work. How can I find out? Thanks, Carl
  • 210 Answers
SOURCE: ie problem on lg dishwasher
The IE is telling you it is not getting enough water. Could be your water pressure is low. Check to make sure the there is not a build up of grime, or calcium deposits in the water hose, and at the valve.
The other thing is if your unit is an older one, prior to mar 07, you may have broken wires in the door. Remove the door panel and look for any wires that are stuck in the insulation. The sensor wires are thin and gray in colour. Splice the wires and put some of the white insulation in between the wires and the door so it cannot happen again.
Broken wires can be hard to find if the break is not all the way through.
Sgt Lauder
Posted on Jun 02, 2008
MNTECH
  • 1543 Answers
SOURCE: LG Dishwasher
Take the main wash arm off and the sump cover below it. Remove the part you'll find under that to gain access to the cutter blade attached to the end of the motor shaft. Remove blade but note that this is a LEFT HAND SCREW. Now lay dishwasher on it's side and remove screws and electrical plug to motor. Reverse procedure to install new motor. It's not really very difficult.
Posted on Oct 21, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: does a LG model LDF 6920st have anything way to heat to hot water
Dishwashers do have a water heater element. In fact, it's the same heater that is used for hot dry, but you can switch it off for the drying cycle if you want. Dishwashers heat the water so it will be hot enough to properly clean the dishes. Sorry, you lose the bet.
Posted on Nov 26, 2008
  • 3 Answers
SOURCE: not heating /lg ldf 6810 st dishwasher
Using the programs, how did you determine that the heater unit was defective. I tried, set to 36 (10 second heater unit). Do I feel for heat. I just assumed that was it and ordered a part, but it would be nice to be able to confirm.
Posted on Nov 27, 2009
  • 3230 Answers
SOURCE: LE error message
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Good Luck!!
Posted on Mar 27, 2010
Lg 3850dd3006e makes noise
I had the same issue with my LG it has a stainless steel impeller the grinds up the food particles and if one of the veins get slightly bent it causes that problem. The tack took it out straightened it out until the new part arrived and it worked fine. He did return to replace it but I don't think it was needed
Jul 29, 2012 | LG 24 in. LDF 7811 Built-in Dishwasher
1.The dishes are not getting clean. 2.It is not
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 26, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Strange noise when using the dishwasher
The sound may generate form inlet Solenoid. It may come from water pump also. Check inlet water flow also for proper pressure.
Apr 15, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Drying cycle vents at bottom of door causing a slip hazard
call the manfacturer and give them give them make model and year of machine.If problem they may be aware of it and should be able to help you
Dec 16, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Does Not Dry Dishes
Withe the model and serial number it appears that this dishwasher is less than 2 years old.
Your symptoms point to a failed heating element. That is kind of surprising because this dishwasher ~should~ report an error code if the thermistor does not detect the raising temperature from the heating element.
The LG LDS and LDF models do NOT turn on the heating element in the drying cycle. It turns it on during the final rinse and the dishes dry as the built in fan runs.
So, I suspect the drying fan and related gear is inside the door panel. Do a load of dishes and listen for the final rinse to drain. Then, listen really closely near the top of the door for the quiet sound of a fan _and_ place your hand underneath the left hand side of the closed door for warm air blowing straight down.
If you do not hear./feel what I discribed , the drying system has failed. OH, and if you have any water leaking from the door (right where the warm air is supposed to come out, contact LG service folks and firmly request that they replace the drying parts with a retrofit kit.
Please review this and tell me what works and what questions you still have.
Good Luck and please keep me posted! OK?
Mar 24, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Two days ago my LG dishwasher model lDF 7810BB worked fine. Yesterday I loaded it and the display panel will not light nor show any sign of power. I check the circuit breaker several times and all other...
Check for voltage with a multimeter at the wires very near the front, just behind the kick plate. Follow the incoming electrical wire in and remove the little plate the covers the wires/wire nuts. I have seen wires that appear to be connected properly but the circuit is open.
Or, even though the circuit breaker is not switched open, the circuit itself, supplied to the front of the dishwasher is not live/hot.
Good Luck!
Mar 08, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
Hi. I have a 3 year old LG dishwasher. It will not drain. Display shows OE. I completely cleaned the drain assembly inside the DW. I checked the discharge line, it is completely clean. I disconnected the...
Measure the electric resistance of the Drain Motor. (Value should be 20-40 Ohms) If it is out of spec, replace it.
Please reply with what worked best. Thanks!
Dec 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
LG dishwasher doesn't heat water
I had the same issue with my LDF7811 about 2 years into its life. I replaced the heating element and that took care of it. Not a terribly difficult job, but it will require removal of the dishwasher and dismantling it from the underneath.
Dec 18, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Does a LG model LDF 6920st have anything way to heat to hot water
Nov 26, 2008 | LG Dishwashers
LG LDF 7811
welcome to the wonderful world of LG. try calling for service a service company should be able to order them and mail them to you.
Nov 05, 2007 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
352 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
