Question about Bose QuietComfort 3 Acoustic Noise Cancelling Consumer Headphones
Sound from both ear phone
When I plug the ear phones using the line that goes with the unit I hear only one side--when I use a different wire both sides will play only if I hold the wire in a certain position. also there is no volume control no matter where I set the cd players volume. I have a Bose cd player that is approximately 10 years old. will43@email.com
  • 1 more comment
  • saud82 Sep 29, 2008
    i have the exact same problem.. any fixes?
  • V1ad Oct 26, 2008
    I have the same problem with QC3 (2.5 hears old) - right speaker works when I keep it in certain position. I think, it may be a wire, because I keep twist headsets to store it in the case.
  • Anonymous Jan 09, 2009
    I have the exact same problem. Apparently no fix has been identified...
I had the same problem. The issue (if you confirm it is not the audio cable) is with the connection where the audio cable is plugged in. It is obviously not designed to withstand connecting and disconnecting the cable with each use. This is required so you can store the headphones in the provided case. I called Bose and they said they offered no repair but would replace the headphones for $100. My problem is that I have already spent $400 to buy the headphones and feel they should be designed to last longer than 2-3 years. I'm extremely disappointed and would advise anyone against buying Bose products if they are not going to offer any better service than that.
Posted on Dec 30, 2009
Same problem...still no solution?
Posted on Oct 28, 2009
  • 40 Answers
You may need a new headphone plug
Posted on Jul 25, 2008
My nokia radio off
If you turn on your radio and it does not come on as you say, there are different sides to the problem.
1. If when you turn it on, it does not come on, and probably tells you that 'enhancement is not supported', then the problem is from the enhancement (ear piece). Get another enhancement and try again. If you have done that and it still was not helpful, or the problem was not even from the enhancement, then proceed.
2. If when you turn it on, it shows a station or frequency number on the screen, but you dont hear anything, then the ear phone of your enhancement is faulty. To confirm that the problem is from the ear phone, select
options> loudspeaker.
If you hear the sound, it confirms that the ear phone is bad.
You can then use your old enhancement on loudspeaker or get another enhancement.
Hope that helped?
Success.
May 10, 2011 | Nokia Classic 2700 Cell Phone
The right ear phone doesn't work but the other one does
check that the wiring in the plug is not broken. if you pull the plug out a little so that one contact in the jack contacts both sides,you will hear the dead side come on. If it does not,the wire is either broken in the plug ,or where the wire goes into the headphone.
Dec 30, 2010 | Bose QuietComfort 2 Consumer Headphones
One earbud stopped working
what happens is inside the cord where you have your ear phones connecting to your ipod, there is a thin wire that can easily brake. it happens if u for example, rap your ear phones around your ipod. if your rap the chords to tight, the wire can break. it can even brake when you move the cord too much. such as spinning it, shaking it and such.
the wire that breaks connects to one side or both sides of your earphones, which produces the sound. if you can hear only on one side, the cord is damaged and cant be fixed.
i would go and buy new ear phones
i perfer skullcandy in-ear earphones because the wire is secrurly wrapped, and doesnt brake easily such as other producers. the skullcandy ear phones are in my mind are much better then other earphones. you actually feel like your in the room or at a live show.
Apr 20, 2010 | Philips Ear Bud Headphones with Virtual...
When someone calls me on my i465 phone they can hear me but i can not hear them it been like this for 3 days so now i i have to use my ear piece
The earpiece volume could be too low to hear. Try adjusting the volume using volume keys on the side of the phone while on an active call (try dialing the number for checking your balance/available minutes)
If this doesn't fix the issue, the problem could be network or handset related.
Call your Service Provider on a different phone line for them to troubleshoot the phone.
Dec 14, 2009 | Motorola Mobility Clutch i465 Cell Phone
When i talk on my celler phone, you really can't hear the person that's talking on the other side. I bought this celler phone at the date 03/31/2009.
1. Try plugging in a wired headset, or using speakerphone.
If the sound quality is better (via the other 2 methods) - than it is the in-ear-speaker that is defective.
A defective in-ear-speaker should be covered by the manufacturer's warranty -as long as the white water detection sticker inside the battery compartment is still WHITE, and the phone doesn't show signs of being crushed or dropped. (So if you have AT&T wireless they should replace your phone free until March 31st 2010.)
Dec 01, 2009 | Nokia 6085 Cellular Phone
When you are on the phone, you can hear the ring of a call on another incoming line in your ear
check inside wiring connected to jack for this phone.It is possible old sub-standard category -3 cable was used which would cause inductive cross.If that is the case use cat-5 or even cat-6 cable.The difference is the twists on this cable are tighter ,therefore eliminating most inductive cross.
Oct 02, 2009 | General Electric RCA-25424RE1 4-Line...
Can't hear anything when I used my bluetooth ear piece
When connecting, you must be sure the phone is set to connect to the model of bluetooth earphone you are using, and the connection goes through, Once it makes the connection, it will stal connected until you disconnect it, again using the phone's disconnect key.
May 26, 2009 | Google Android
I have a hp fax 1010 problems sending receiving
Are you plugging the phone line into the line jack or the phone jack on the fax machine, it should plug in to line. Also try and unplug/replug the units power cord as well as trying a different phone jack location.
Mar 25, 2009 | HP 1010 Plain Paper Inkjet Fax
Headset mic doesn't work
Disconnect the all lines and power
Remove battery of the headset
Put battery back in
Connect phone line
Connect power cord
I am trying this according to Thomas 800-511-3180
Jan 16, 2008 | RCA 25110RE3 Phone
I can only hear out of one ear of my ear phones and sometimes I hear no sound at all
Perhaps you can open the player and solder the head socket it may have some dry joints there.
Jul 24, 2006 | Dell Pocket DJ MP3 Player
Bose QuietComfort  3 Acoustic Noise Cancelling  Consumer Headphones Logo
700 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
