Question about Clymer EvinrudeJohnson Outboard Shop Manual 48 235 HP
How to disconnect shifting lever on a 1994 Evinrude 48 hp outboard motor. I have already bought manual, but cannot see how this disconnects.
    Problem Solver:
  • 5 Answers
This is a long shaft, should disconnect just below carburetor. Pull all the way out of mid section.
Posted on Oct 02, 2010
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
How do i replace a shift lever on a mercury 6 hp 4 stroke outboard 2006
Hello, is it the external shift handle you want to replace?
Then you'll have to remove the engine block from the driveshaft housing.
To do so: Drain the engine oil.
Disconnect the throttle cable from the carburettor.
Disconnect the start-in-gear cable from the recoil starter housing.
Disconnect the fuel lead at the fuel connector
Disconnect the choke puller at the carburettor.
Disconnect the white and black wire from the stop button at the engine-block and engine wires.
Remove 6 bolts holding the engine-block to the driveshaft housing.
Lift the engineblock.
The shift lever is fixed with a M6 bolt in the front-top of the driveshaft housing. You'll need a new gasket, Part Num 803508-9
May 04, 2014 | Mercury Marine 4hp & 6hp Stroke Outboards...
Evinrude 65hp 65853B Shift lever stuck
Yes, it will be corroded. Just have to find where.
Look to remove the cable from the link arm in the motor.
Can you now set the throttle lever in fwd and rev? Does the cable moves? If Yes, it's in your engine that you have trouble. If no, disconnect cable at the throttle lever and re-check...
If it's the engine: Remove the gearhousing. If now you have movement, the gear housing is stuck ( water inside that has corroded everything, good luck)
If still no movement, check the linkage, you'll have to remove the engine block from the exhaust plate.
The best is to find a service manual to get the right way to disassemble and reassemble...
Oct 13, 2017 | Boating
How do i disconnect shift rod from 1994 60 hp johnson vro
You may be able to find more information on the boating forums.
Mar 17, 2013 | Boating
Size of prop for 1994 evinrude 90 horse power boat
Hi, it would probably need a 17 inch pitch and then water test it and make sure its full throttle revs are between 5200 and 5500. regards Phil.
Aug 16, 2012 | Clymer EvinrudeJohnson Outboard Shop...
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
1977 115 hp evinrude outboard water pump problem
Depending on the year motor, make sure the throttle is in the neutral position, drop the lower unit and the motor foot should come off, will probably take some wiggling and with the age of the motor, possibly a few light taps around the cavitation plate with a mallet would be helpful.
Mar 28, 2009 | Boating
Clymer EvinrudeJohnson Outboard Shop Manual 48 235 HP Logo
323 people viewed this question
Top Clymer Boating Experts
Fabrice Wolters
Colin Stickland
Colin Stickland
Are you a Clymer Boating Expert? Answer questions, earn points and help others
