Question about Crosley CFFH10W Top Freezer Refrigerator
The upper fan behind the freezer box does not start-up. How can I tell if it is the fan or if it is something else causing the problem?
    President:
  • 1,796 Answers
Hi!!
Unplug power cord and remove the back freezer wall, usually 4 screws or clips. (If equipped with ice maker, turn water supply off and remove ice maker first), unplugg fan electrical connector, plug power cord back into wall outlet and check for 120v AC, if power is present fan is defective, replace.
You can by the fan at almost any hardware store or appliance parts center, price runs about $20.
Good Luck!! Don't forget to rate this post!!
Posted on Aug 27, 2010
Freezer fine but fridge warm
The fan seems to be out looks like you need a new fan motor for freezer component
Nov 14, 2013 | GE PDS22SIS Bottom Freezer Refrigerator
Where I can replace the fan that supply the cold to the ref at the upper part. Because the fan is not working...
hello,
the fan tha circulates air throughout the entire box is located in the freezer,behind the back wall
Aug 06, 2011 | Kitchen Ranges
I have a LG model LFX25960ST refrigerator with an error code of FF. I know this means the freezer fan, but is that one of the fans located in the freezer? When looked up online, neither of those two fans...
yes, its located on the freezer; behind the rear wall. yours has 2 fans; one for the ice cube room (upper left corner) and the fridge/freezer motor (in middle) behind rear freezer wall. this is the motor you will need. the part number should be on it.
May 10, 2011 | LG LFX25960ST Stainless Steel French Door...
My refrigerator and freezer working fine,but the door jam between freezer and frig gets very hot can anyone tell me why ?
Either the fan which cools the coils and compressor , behind the rear panel behind the refrig , is not working ( or something is caught in the fan blade ) , or , the coils under the refrig need cleaning badly .
Jun 19, 2010 | Whirlpool ED2FHGX Side by Side...
Kenmore refrigerator with bottom freezer. freezer works,refrig does not. Can you help me find the problem .Also, bar between the upper doors gets real hot.
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
That's what worked for me.
Jan 12, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Whining fan
In the rear of freezer upper panel must be removed to get to it,possible cause that something has been pushed against panel making fan rub or ice formed around it.Addres the cause of problem because fan is needed for unit to cool refrigerator.
Apr 22, 2009 | GE GSL25JFR Brushed Steel Side by Side...
Loud shreaking sound coming from Kenmore Frost Freezer.
The fan behind the molding is hitting some ice build up and causing the sound. Sounds like the timer for the defrost isn't working. Try to turn off the unit for few hours or take off the molding in the freezer compartment and remove the ice build up with hair dryer.
Nov 23, 2008 | Kenmore Freezers
My GE GSS22SGMBBSCC side by side refrigerator does not cool the upper freezer portion
Most newer GE fridges have dc fan motors controlled by a computer board. Sometimes the board just fails and sometimes the fan can cause the board to fail.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My 16-year old refrig makes a single knocking noise when it starts to cool. It sometimes makes that noise if it's just sitting there. Just replaced the fan assembly behind the freezer wall. It wasn't...
Just a thought..fan motors usually have some front to back play (looseness). When the fan first turns on ..it may make contact with something, however after a few blade revolutions, the air pressure will push the fan one way, and allow it to be quieter. If not the fan, the compressor will also have some starting torque possibly causing a knock.
Apr 20, 2008 | Refrigerators
Upper Fridge Too Warm
We had a warm fridge and super cold freezer.....we unplugged for about 20 minutes and the fridge started to cool down again.... but only for a few days then back to warm.
We ended up unplugging and "defrosting" the whole unit for 24+ hours ....Now it works perfectly again.
I think it happens when one or both of the doors is not shut or sealed all the way and engine works too hard and "freezes" up the fans or some other part of the system.......I am just happy I did not have to buy a new fridge.
Mar 30, 2008 | Maytag MB2262H Stainless Steel Bottom...
Refrigerators Logo
Top Crosley Refrigerators Experts
Charles T Nevin
Charles T Nevin
fta777
Colin Stickland
Colin Stickland
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
