Question about Poulan "Poulan" Push Mower
Lawnmower starts and dies... where is the main jet for the carb?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 296 Answers
Try cleaning the air filter, then a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season.
Posted on Oct 08, 2010
Craftman silver lawnmower starts runs 30 seconds stop mt gas tank refilled cheched oil cleaned air filter whats next
Sounds like you have an issue with carb main jet. Latter needs cleaning or carb rebuild or replacement.
Sep 05, 2017 | Garden
Lawn boy 10685 starts but will not run
clean the carb there is dirt in the jets
May 03, 2012 | Garden
1963 vw newly rebuilt engine, starts then dies at RPM acceleration
Could be one or both of two things.
1. The accelerator pump in the carb is clogged, the linkage is unhooked, or the diaphram in the pump is bad. It's cheap to replace and comes in the carb rebuild kit. This usually just causes hesitation when you step on the gas pedal. It doesn't usually cause the engine to stop running.
2. More likely is that the main jet in the carb is clogged. At idle, high vacuum under the closed throttle plate in the carb causes fuel to flow thru the idle jet. As the throttle plate opens (as you step on the pedal), the vacuum under the plate dissipates, stopping the flow of fuel thru the idle jet, and the vacuum ABOVE the throttle plate increases, which is supposed to then draw fuel from the carb bowl thru the main jet in the carb. If the main jet is clogged with dirt, then it can idle just fine and die as soon as you step on the pedal.
Jul 24, 2011 | 2000 Volkswagen Beetle
Lawnmower will start, but dies. want to install new seat and needle.
Mower starts, then dies (user said)...classic symptons of a clogged main jet (the brass bolt for float bowl). In other words, fuel flow is NOT continuous through the carburetor.
Jun 27, 2011 | Mtd 22" Yard Machine Push Mower
Centura 3.8 HP Tecumseh lawnmower not working w/o starting fluid
main jet blocked needs carby service its worth it
May 12, 2010 | THQ The Lawnmower Man
My Toro revs up and down and is shutting down. New sparkplug, new air filter
Two things to check: 1) A restricted fuel filter would cause this problem. 2) Debris in the carburetor. My lawnmower would start, rev a little bit, then die. I could keep it going with the primer pump. The problem was the main jet in the carb was obstructed. The solution was easy since there was a plug on the bottom of the carb which provided access to the main jet. I removed the plug then removed the jet with a 6mm wrench. I cleaned it with carb cleaner and re-assembled. Ran great after that.
Good luck,
Techjoel
Jun 05, 2009 | Garden
Starts, runs, and dies...starts, runs and dies...starts, runs, an
Sounds like a common fuel problem you need to remove carb & fuel tank and unless you can get a compressor they need a good blast out you may even take carb apart & check diaghram they have very small jets in fact most lawnmower shops have a sonic bath for this
Apr 25, 2009 | Poulan Pro " Pro" Self Propelled Mower
Murray lawnmower
you may just need to remove the nut that holds the float bowl, and inspect the nut itself, half way up the nut should be a little tiny hole in the side.
use a bread tie stripped of the plastic covering and unclog this little hole, then replace the nut , when that hole becomes plugged the main jet cannot get fuel for the venturi pipe, thus the mower will start and hit a couple times then die immediately, that may fix the problem
Sep 15, 2008 | Garden
Poulan "Poulan" Push Mower Logo
811 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
