Question about Husqvarna Sewing Machines
I have a very old Husqvarna sewing machine which does basic things like button holes, zig zag and straight stitching. Can I get a foot for this machine which rolls hems. Thanks
  • 340 Answers
You should be able to get a rolled hem foot for your machine, although I don't know what model you have to help further.
http://www.husqvarnaviking.com/us/media/Rolled_Hem_Foot.pdf
Try having a look on the Husqvarna site for accessories.
Posted on Aug 27, 2010
The feed dogs on my sewing machine will not raise
if your question is that the fabric didn't feed when I tried a zig-zag stitch , well then this might be a normal thing to happen on your machine , some machines when set to MAX size zig-zag stitch retract the "feed dogs" as you call them so that the operator can hand move the fabric around under presser foot , this is task called "darn" and its usually for filling large holes in fabric (socks!!) and for adding embroidery too (special needle)
Oct 05, 2016 | Sewing Machines
Can't get the Husqvarna Viking Platinum 775 to do a zig zag
it's very possible that a cam or gear has worn down or broken
inside the machine and also if the sewing machine is computerized
then there could be a problem there, having the machine checked
would tell you for sure.
Nov 08, 2012 | Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
I have a Kenmore model 1690. The needle when it goes down does not hit the hole in the foot plate. It comes down too far to the left of the opening, making it impossible to use the machine. I have...
This machine, when you have it on straight stitch, will sew with the needle to the left. If it's hitting the pressure foot, you may have the wrong pressure foot on the machine. If it's hitting the needle plate when you have the pressure foot removed, it's possible you have set for zig zag and you have a straight stitch needle plate on the machine. I believe this machine came with 2 needle plates. One for straight stitch, and another for zig zag.
May 03, 2011 | Kenmore Sewing Machines
What foot should I use for basic stitch or zig-zag stitch?
a all purpose foot or a zig zag foot will do both straight stitch & zig zag
Dec 16, 2010 | Singer Sewing Machines
I cannot get my tension adjusted correctly. I have lost my manual. Can you give me some help. Also, do I need a separate foot for the zig zag stitch.
usually a tension of 3 or 4 is good
only if the presser foot not is not made for zig zag--all the presser foot's that I've seen on new machines do straight stitch & zig zag,, if the opening in the foot is large then manually try a zig zag stitch to see
Nov 22, 2010 | Brother XR-65t Mechanical Sewing Machine
I need to adjust the needle so when I zig zag it will not hit the plastic. It works perfect on stright stitch.
You might have the zig zag set for z-z left or right-hand. Make sure you are choosing the zig zag centre stitch. Also check you are using the correct foot - it should be the A or B foot with the wide opening.
Apr 06, 2010 | Husqvarna Viking 1
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
85 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
