Question about Hunter 21871 56'' Ergonomic Brushed Nickel Ceiling Fan
I purchased a display Model 21871 (Hunter Ergonomic) fan from Home depot. No instructions or diagrams. The unit has 6 wires, they are: Black w/Grey stripe, White, Grey, Pink, Red, yellow. The new remote that that they gave me is a Hampton Bay Model 191-691. In addition to the Black and White line voltage input wires, it also has 3 other wires. The black one is labeled "To Motor L" The white one is labeled "To motor N". The blue one is labeled "For light" Can you please tell or show me how to wire this up.
  • 1 more comment
  • leotoi Aug 27, 2010
    I have many more wires that the first solution supported
    No one has addressed the fact that there are several more wires in the fan. Pink,red, yellew, grey etc. where do they go?
    Your help was the best I received. After seeing the wire diagram, I concluded that the Hampton Bay receiver is not compatable with the Hunter Fan and lite. I will return both units to The Home Depot and purchase something other than the display. Thank you for your help.
  • 10,865 Answers
Posted on Aug 27, 2010
  • 857 Answers
Please follow these indtruction:
•1
Turn off power to in your breaker box. Test the switch to make sure it is off. Use your electrical tester if you're not sure.
•2
Bring wires down after the installation of the hanging bracket (see Resources below). Your hanging bracket should be installed with the wires hanging through the middle of it for easy access.
•3
Strip the ends about an inch.
•4
Twist the ends of your wires together and join them with a plastic nut. Connect your wires in one of two ways: To control the light fixture separately, connect the black and white wire leading from the fan to the wall switch.For no light wall switch control, bring the black and white wire together from the fan to the ceiling black wire. This is for instances where there is no wire for a light fixture.
•5
Take your ground wire and put it around your ground (green) screw. Tighten it in place.
•6
Place wires through the canopy.
For detailed steps and pictures go to this link below:
http://www.hammerzone.com/archives/elect/fixture/ceiling_fan/01/hunter_23843.htm
If you want you can also look the INSTALLATION AND OPERATING MANUAL FOR HUNTER CEILING FANS from the link below:
http://www.costco.com/images/content/Misc/PDF/906146.pdf
HOpe this helps you.
    Sergeant:
  • 252 Answers
The two black ones screw into your AC line voltage. The white wire is the ground as you know screw it into your ground wire. The extra white wire acts as a common ground it screws in with the naked shiny copper wire that is part of your AC line. If you have an older house you mite not have the naked shiny copper wire. If you dont just tie the extra white wire into the ground wire of you house. Then find the light fixture that attaches to your ceiling fan and connect the green to it look closely to the fixture you will see where it goes. If you have another wire coming from your light fixture tie it into the ground coming from your house
  • 2 more comments
  • Willard Broughton Aug 27, 2010
    I was working with the wires that you gave me in your explanation.
    You have to give us that information. We cant see your product often time we only see what it looks like you have to explain how many wires they are what color and what label they have on the them.
    I thought it is pretty clear that there is 6 wires coming from thr fan and light and 3 more wires on the remote receiver as well as the normal black wire and white line voltage wire also on the remote receiver. A total of 11 wires to work with.
    You did Im sorry
Hunter fan switch doesn't work
I had this same problem. Home Depot and Hunter did not help me. I called Ken's Electronics in Kalamazoo Michigan Phone (269) 345-4609
website http://www.kenselectronics.com/index.html. He was excellent and very knowledgeable. Got repair part for about $7.00 and received it within two days. Great. I was so frustrated because it looks like I was going to have to purchase and install a whole new fan. Started to wonder if Home Depot and Hunter did this on purpose. Call Ken and he can help with questions and installation too.
Dec 01, 2011 | Hunter (25417) Ceiling Fan
Fan will not work, but light will. it is model # 21871a-420. the remote will not work either function. there is power at the box. i purchased a new Hunter universal remote model # 27227 and the wiring is...
You have to get the correct receiver for that fan. There's no such thing as a universal remote,no matter what it says on the box. Call 1-888-830-1326 and you can order your correct part.
Sep 04, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Remote missing on a Hunter Ergonomic fan. do not know how to take the base cover or light cover to see serial number. light cover has screws with no slots. base cover has no sign of srew holding it up. How...
Purchase the remote control, install batteries, and try it before taking anything apart. If the new remote control does not work, the internal receiver may have failed.
Dec 07, 2017 | Hunter 21871 56'' Ergonomic Brushed Nickel...
We purchased the Hunter Ceiling fan over a year ago and it has worked fine up until a couple of weeks ago. When we turn on the light it just continuously blinks on and off.
there is a watt governor, or black box for the lights to cut down on wattage or energy use. you can remove the black box for the lighting, and wire it directly to the main wires. white wire to white wire, and black wire to red wire. black and red are always a hot wire and white is a neutral wire. the part number on black box should be 98480-02. this should stop the lights from blinking. have a good day !
May 28, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
How does the receiver of the Hunter model 21871 ceiling fan attach to the canopy? There are two things on the receiver that seem as though they should connect to the canopy with slots but no slots in the...
if you look at the mount bracket where the ball of the fan fits in to it should fit right above the ball in the mount bracket and if it can fit loose in the canopy thats ok to just long as ou can get the bell housing back up
Jan 23, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Bought a display hunter 20171 Ergonomics C Fan. The wires were cut short, remote control receiver not included.
have no choice but to buy the original receiver through hunter - not a replacement from HD or Lowes - it will not work.
Nov 27, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
The canopy doesn't seeem to fit flush up against
You just need to wrap it and tuck it .. You might need to cut some of the fan wires shorter so there is not so much bulk under the canopy cover. The fans are shipped with enough wire leads to be able to use a down rod, They can be cut shorter when the fan is being installed.
Mar 02, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
About two years ago, I purchased a: Hunter 56 In. Brushed Nickel Ergonomic™ Remote Control Ceiling Fan Model 21871 A few months ago, a bolt of lightning struck through my house and my fan...
To have a contractor in your area look at this unit, try using the contractor search on the home page of fixYa, or simply use the yellow pages for your area.
My guess is that the lighting burnt or damaged the motor windings in the fan. I am sure that replacing the motor would solve this issue. I do not know where to find one though. I hope this helps some.
Jul 03, 2008 | Hunter Heating & Cooling
Hunter 21871 56'' Ergonomic Brushed Nickel Ceiling Fan Logo
1,388 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
