I have a Carrier Infinity System that has the "auto" setting which is where I usually keep it in the spring time to go back and fourth as needed for proper temp control in the house. About once a year, I get a "Sens Error" because the A/C tries to cool when it is below 60 outside. Is there a simple way to bypass or turn off this function, or do I need to call my dealer, and waste a $75 service call to get this taken care of?
  • BVeneman May 06, 2008
    Well, that book is what I have been going by at home, it is about as helpful with this problem as a screen door would be on a submarine.
    I know there is a way to clear the error, and that's what I'm looking for. The book does not give me that information.
    How do I get to the Cooling Lockout setting on the control panel?
  • 3,037 Answers
There should be a setting on the control panel labeled as cooling lockout with a default setting of "none"
you can switch this to a lower temperature and that should fix the problem by not providing any A/C once the temperature gets below the point.
Let me know if you have any further questions and I would be glad to help
Posted on May 06, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri May 06, 2008
    It should be in the menu under setup -> Heat Pump/AC
  • Benjamin Patri
  • Benjamin Patri
    Benjamin Patri May 07, 2008
    Please don't forget to let me know your thoughts about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
  • 19,396 Answers
You need to select specific day and times when you want this or that temperature. Refer to this manual pages 3 to 10
  • Ginko
    Ginko May 06, 2008
    Check also 'PROGRAMMABLE FEATURES,
    SETUP & OPERATION'', from page 16 onward. And program the conditioner on different settings in warm period.
    President:
  • 2,712 Answers
Hello BVeneman.
I would reckon that there is an issue with the thermistor on your machine. Unless you know how to get it replaced, I suggest you get a professional to look into it. It will be worth it in the long run..
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
I have carrier infinity heat unit split system now my thermostat keeps saying comm error
Unplug the AC unit for 5 minutes to see if it will reset and clear the communication error.
Nov 18, 2016 | Carrier Heating & Cooling
Bobbin case won't close, error message coming up that hook system won't engage.
1. The bobbin carriers usually have a spring on top and little parts on each side. The carrier must be installed so the holders on each side are keeping it from spinning either direction.
2. Rotate the hand wheel until the opening is noticeable. This is where you need to install the carrier.
3. While installing, the spring must be pulled up slightly to get the carrier under the spring.
4. Try to rotate using the hand wheel. There should be no rotation back and forth. Don't make the edge brackets too tight against the carrier. The thread has to go through this area.
5. Once you have finished this put the bobbin in. Now, it should work.
Apr 03, 2015 | Sewing Machines
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
CARRIER INFINITY WEATHERMAKER WHERE IS THE RESTART SWITCH
Carrier Infinity systems, do not have a manual reset switch. It will have an automatic reset depending on the failure.
I would first, turn off the breaker to the indoor and outdoor units. Wait about 5 mins and turn the breakers back on. Doing this will reset the Control Board in the system. The system itself, is probably locked out.
This should get the system to come back on, However, you may have the problem come back and lock out the system again.
If this happens again, i would advise calling a Carrier dealer with Infinity systems to test it.
Hope this helps
Brian
Nov 28, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier infinity a/c thermostat screens are blank - no power
There is a fuse in the control panel, and depending how they wired it may be a inline fuse. also there is a fuse in the airhandler also they both should be a 5 amp auto fuse.
Jul 18, 2010 | Heating & Cooling
Problem with new Carrier Infinity 96 gas furnace
carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
Nov 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Infinity Auto Bose disc player does not play. The
THE UNIT HAS A PROBLEM WITH THE GEARS SLIPPING ON THE SHAFT , NEEDS TO BE SENT BACK. REPLACEMENT OR A SYSTEM UPGRADE WILL FIX THE PROBLEM. SOME PEOPLE HAVE TAKEN UNIT APART AND PUT GLUE ON THE SHAFT AND SLID THE GEAR, BUT THAT DOESN'T SEEM TO BE A PERM FIX. AND IF YOU MESS WITH IT BOSE MAY NOT WORK WITH YOU ON THE PROBLEM ...
Jul 30, 2009 | Bose 3·2·1 II System
The Infinity Comfort Control code
Call your local Carrier dealer. They have code to get into system. Rusty Good system
May 21, 2009 | Heating & Cooling
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
