Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
I have a rancher 55 it does not have any spark not sure if its the coil or something else any ideas on what to do or replace it has a brand new plug in it and wires look to be in good condition this saw hasn't had much use on it
    Problem Solver:
  • 9 Answers
Probably the best thing you can do, if you haven't already tried it. Is to take the spark plug back out, leave it connected to the lead, earth it to the cylinder somewhere and pull the starter and look for spark, if no spark, pull out the spark plug and stick in a screw driver into the lead and hold it just off the cylinder, look for spark again. If still no spark there is a fair chance you coil is no good. Also, it is possible that the spark plug could be faulty even though it's new. Good luck and i hope this helps.
Posted on Aug 27, 2010
No spark on Huskvarna Rancher 55
disconnect any and all kill wires going to the coil... if you still have no spark then it can ONLY be the coil... if this produces spark then you have a kill system problem or your flywheel has no magnetism... and this can be the only solution as you do not have points/condenser or things just went full derp
Aug 27, 2014 | Garden
No spark with Huskvarna Rancher 55. New coil
anon re connect the kill switch. If this fail try connecting the two ends of the wire to the kill switch together.
Huskvarna Rancher 55 (~2000) no spark
could be in your switch. the ground wire needs to be attatched for new coil to work
Aug 26, 2014 | Garden
I have a Huskvarna Rancher 55 ~ 2000. Suddenly no spark.
check your ground wire and switch as well
Husqvarna rancher 55 chainsaw having problem starting have spark new spark plug, plug is wet after trying to start it
You need to check that this machine is mechanically sound, remove the muffler and check the condition of the piston skirt through the open exhaust port, any signs of scuffing ( seizure ), and the cylinder will need to be removed to assess the damage
Aug 27, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher Starts fine and runs great for about 5 mins. Stalls and wont restart until cold. Problem than repeats
Try removing the fuel cap for a moment to see it can be restarted immediately. If this works, check the fuel tank vent for plugging problems. Also, check for spark at the plug when it dies--if no spark, try a fresh plug gapped at 0.020". If nothing, the ignition module may be failing with heat. Good luck!
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I own a 99' Husqvarna 55 rancher that suddenly just cut off. I pulled the plug while it was cold and didn't get any spark. I took the cover off to access the coil, checked flywheel magnets and one of them...
Try sticking a piece of iron or steel to each magnet face which should hold firmly. If ok, concentrate on the ignition module. Remove the single wire attached to the body of the module and try for spark again. Be sure to try a fresh plug gapped at 0.020" to make sure the old one did not short out internally. If still no spark, replace the module. Use a thin business card for a pole gap gauge. Turn the flywheel magnets under the module, insert the card, and allow the module to contact the magnets.
Tighten the module screws, then turn the flywheel somewhat to remove the card. Turn the flywheel one full turn to make sure the gaps don't close further. Don't forget the stop-switch wire connection. Hope this helps!
Jan 16, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna ranger 55 chainsaw starts but quits
I too have a rancher 55 and had what sounds like the same problem this week. It would start fine but run for only a few seconds at a time. I took it all apart today and found the problem - a cracked fuel line. In the places where I could see the hose it looked fine, but it wasn't until I removed the fuel tank that I found the crack...right where it exits the tank and then goes thru the housing above it. You don't need to remove the tank to replace the hose but it is easier that way. You do have to push it thru a grommet at the top of the tank. I read some other posts about checking the tank vent to see that it's not plugged up. Mine was ok so I knew it had to be something else. The vent is in a hole about the size of a pencil and is recessed about an inch into the tank on the upper right side. Its partially covered by a plastic cap that's part of the vibration damper, which can be removed to gain access to the vent. The vent tube can then be pushed out from inside the tank with the use of long needle nose pliers, but be gentle. I just loosened it then pushed it out with a finger. I put it all back together with a new hose and its running like new again!
May 28, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarana Rancher 55 , how to clean the exhaust port
Cleaning the exhaust: on the saws I've worked with it was just to loosen two bolts at the front and then the exhaust is off the saw. Clean with brake cleaning fluid and blow with compressed air, let it dry before assembling. Don't forget to clean the fine mesh at the output side underneath the lid if present (i.e the spark arrestor).
Make sure to have your carb adjusted properly afterwards.
May 18, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
145 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
