Question about Panasonic Vacuums
Belt burned up (first time); installed new belt but that starts to burn also; approx. 2 years old
  • 377 Answers
Sounds like the brush that the belt is supposed to turn is bound up tight. Need to remove the brush and clean all debris from it. Where you can get at the center rod for the brush, the rod that the brush spins around, clean the ends and add some WD40, being sure not to get it on the belt. This should remedy the problem of the belts burning as long as the belt is put on correctly.
Posted on Aug 29, 2010
I put a new belt on my vacuum cleaner and it burned off because the brushes won't turn
Hair, dirt and dust can build up underneath the end caps on the brushroll which can damage the bearings if your brush roll has them. If not cleaned occasionally the debris will cause friction which can keep the brushroll from spinning freely which will cause the fast spinning motor shaft to melt the new belt. The old belt was likely loose enough it did not have enough friction to burn the belt. Many people assume they got a faulty belt when this happens but it's usually a problem with the brushroll. The brushroll is very important to getting dirt out of carpets and should be replaced every few years. I suggest a new brush roll and be sure to remove it occasionally to clean it and put on a new belt at least once a year.
Mar 11, 2017 | Vacuums
Kirby Sentria 2 burning smell (not belt)
Actually it can. If the machine has a defect but the good news is that is has a 3 year warranty. Take it to a Kirby authorized repair shop not a vac and sew and they will fix it right up....I am a factory authorized service tech for the Kirby co.
Dec 16, 2013 | Kirby Generation 3 Bagged Upright Vacuum
Every so often I get a smell of burning from my g4 Kirby vacuum. I noticed it's when I'm vacuuming a fairly new rug on this house I clean. Should I be concerned?
If it is a smell of burning rubber - most likely your vacuum belt is overdue for replacement.
At this point - remove the brush roller, remove the old belt, clean off your brush roller and remove any string or hair that may be bound up around it (usually around where the belt goes or on the sides), and put on a new belt. Your Kirby should act good as new if your bag is replaced at the same time.
If the brush roller has too much string and hair wrapped around it, many times the brush roller will not spin as fast as the belt is driving it and you will get that burning smell.
Dec 23, 2009 | Vacuums
Making a burning smell...not working as it should
remove the brush roll clean the brush end bushings and replace with a new belt
Sep 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
The brush roller stops turning and I can smell the belt burning, then it will catch and start working normal. I looked under the plate to check the belts and they looked okay and no hang ups of string or...
better to replace both belts the smaller one is stretched out thats whyits slipping ,be sure to clean the old rubber off the motor shaft before replacing the belts.it will cause the new belts to run unevevly and go bad before their time
Aug 30, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Burning
A guess: either there is something in the fans, stuck in the tubes or the belt is being held in position by debris causing it to burn.
Nov 14, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Belts Burning
Yes, replace the brush roll, the ends or end is probably bad and causing the belt to slip and burn up.
May 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
440 people viewed this question
Top Panasonic Vacuums Experts
Jim Parker
Jim Parker
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
