Question about Amana ABB1927DE Bottom Freezer Refrigerator
Helo the repair man just left paid him 240.00dollars he fixed the bottom replaced some parts but then the top fridge is not cold felt like he did know what he was doing help
    President:
  • 1,218 Answers
Good day,
If the freezer is starting to come around, then eventually the fresh food section will eventually.
If the fresh food section had warmed up completely before the repair was done, 24 hours for it to stabilize would be normal.
Posted on Aug 27, 2010
Side by Side Maytag MSD2542VEB00 freezer working but fridge is not
you took off the back inside freezer wall and the evaporator coil had frost on it?or was it even over the whole coil,if so that's what it should do,all that happens is that coil gets cold,the evaporator fan blows the cold air over into the fridge section and then there are air vents so the air just keeps circulating,in your machine you have a difusser or a damper part number W10151374,it opens and lets cold air in from the freezer and when it gets cold enough it closes,first thing open the freezer door,you should hear the fan blowing,if you don't you could have a bad evap fan motor,if the fan is blowing but no air blowing into the fridge then it sounds like you have a bad damper,if you open the fridge door the damper is up on the top left side wall,go here and this is a picture of it
http://www.repairclinic.com/PartDetail/Damper/W10151374/1454298 you can also go here and look at part number 4,this is your adaptive defrost board
http://www.searspartsdirect.com/partsdirect/part-model/MAYTAG-Parts/Refrigerator-Parts/Model-MSD2542VEB00/3048/0165000/W1203185/00011?blt=06&prst=&shdMod=
let me know what you find,also if you remove the bottom front kick panel,there should be a tech sheet to tell you how to put that machine into defrost manually,look for a paper tucked into the panel or taped inside that bottom cabinet that the panel covers
Jul 28, 2012 | Refrigerators
My lg fridge lrbn20514bk the thermastat is not working on the top control but for freezer is reading 567
This fridge LRBN20514BK with bottom freezer is a piece of junk. Just had the relay on compressor replaced and now the thermostat isn\'t working. Temperature on fridge reads nothing and freezer temperature reading 5,6,7. Then the freezer coils freeze up and no air blowing to the fridge. Ready to take this POS outside and blow it up. Only 7 years old and never ending issues. I will never buy LG again. EVER! LNG - Life is not good! HELP.....so what needs replacing? Thermostat? And of course I have to have repair man come in due to LG not selling parts to customers. Again I call BS
Feb 03, 2012 | LG LRFD25850 French Door Refrigerator
GE model 25 - 6 years old - Top part of fridge and freezer not cooling. compressor seems to be working fine. Bottom part of freezer is very cold and bottom part of fridge is freezing everything. Appears to...
It sounds like the damper assembly might have failed or be stuck open. The damper is mounted in the left side upper rear corner of the refrigerator section. The damper controls the amount of cold air that comes into the refrigerator section from the freezer.
If you want to repair the refrigerator yourself you should disconnect the power to the refrigerator and remove the 2 screws holding the damper cover to the center wall. Sometimes you can spray the damper with WD40 and free it up.
Jan 30, 2011 | GE Profile PSW26P Stainless Steel Side by...
My is SxS fridge is warm on top & freezing on bottom- both sides
there is a computer board part number WR55X10942 ,if you're in front of the fridge it's on the left hand side down near the bottom,
Mar 21, 2010 | Hotpoint HSS25GFP Side by Side...
Dishwasher cold rinse and low pressure
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jan 18, 2010 | Hobart AM14C-155 Dishwasher
On top freezer works fine, fridge compartment below is not cold.
turn the dual temperature switch to warmer for the fridge to cool down.
Apr 04, 2009 | Refrigerators
I called a repair man. I was charged $150.00 . It was the box at the botom left side of the fridge,under fridge. It's fixed .It took about 5min. to replace it. I could have done it my self. Reading FixYa pointed me in the right direction. Reading postings on FixYa! What a great place to recieve info! I am not sure what the part cost, if you were to install it your self. Not a big job it has two screws that holds it in place. I had to work, was in a bind for repair man. It was worth the $150.00 to have my food back in the fridge.
Jan 17, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
