Question about LG Microwave
Not cooking. The tray turns, but no heating. - LG Microwave
  • LG Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 25, 2011
Glass tray turntable makes noises when heating food
Hi, the rollers on the support mechanism has residue, try cleaning the rollers and the track it follows, should resolve the sound problem
Jan 05, 2015 | LG LMH2016ST 2.0 cu. ft. Over-the-Range...
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
What would cause the glass tray in the microwave to shatter
  • The glass tray had a hairline crack or stress fracture that was not visible
  • It got a little too hot in one area
  • The expansion from the heat caused the fracture to expand and therefore crack and break
An accidental bumping of the microwave plate on the countertop while going from the microwave to the dishwasher might set up the above situation. The spoon your seven year old left in the mac and cheese might have arced and nicked a small piece of the glass. Whatever the cause, microwave trays break and they break for a lot of reasons.
All foods cooked in the microwave produce heat. Microwaves themselves are not hot, but the foods cooked in a microwave get hot - some much hotter than others.
Even though most microwave glass trays are tempered, they are not designed to hold up under high temperatures. You will see most microwave trays stamped with the words "For microwave oven use only" This is to let us know that it's probably not a good idea to use the trays in a conventional oven.
Any air pockets, cracks or gaps in the glass can enlarge under heat. Since glass isn't very receptive to being stretched, breakage can occur.
for more you can read on this link
http://www.ebay.com/gds/Why-did-the-glass-tray-in-my-microwave-break-/10000000003014864/g.html
Aug 27, 2013 | Goldstar Microwave Ovens
All the controls work and seems to be working with tray rotating but makes noise and does not cook
Having noise means some obstruction near the rotating tray or its motor need some lubricant. Has for no cook but control seems working, the magnetron and its fuses is the culprit because it doesn't anymore produce heat to cook food.
I hope that advice help you.
Mar 31, 2011 | KitchenAid KEMC377K Convection / Microwave...
The microwave comes on and tray turns but not cooking/heating. Anything I can do?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Apr 20, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave works perfectly but does not heat
Sadly your microwave has done it's last cooking. The mechanism you need to make it cook again would cost you more than a replacement microwave.
Jul 15, 2009 | GE Countertop Microwave Oven
Microwave not cooking
I would say yes, this can be fixed. It's most likely a relay with burned contacts.
May 02, 2009 | Goldstar MV-1526 Microwave Oven
I have a JVM1603BJ03 space saver micro wave. The turn table cracked in two, the plastic support device to turn the glass table has desenigrated into several small pieces. It appears the micro wave is...
Do you cook a lot of popcorn?
Do you place your food items in the center of the turntable as opposed to placing them off-center?
Both can cause repeated heating of the same spot on the turntable, which can stress it and allow it to crack.
You can buy replacement parts here.
I suggest that when you cook popcorn, place a paper plate or two upside-down under the bag and always place your food items off-center on the turntable tray.
Once you have the new parts, I would suggest at least a quick heat test. That is to heat one cup of water on high and it should boil in about 2 to 2-1/2 minutes.
If you would like to perform a more standard heat test, please see my Ask Mr. Microwave page.
If your magnetron is indeed running too hot, then it is probably dying. Sometimes - like a star - they can burn hotter right before they die.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 04, 2008 | GE Microwave Ovens
Broken turntable
The owner's manual is online at:
http://www.emersonradio.com/owners/MWO%20manual/MW8992SB-RD.pdf
You can contact Emerson at their number in the manual for a replacement.
I always suggest that people place food (especially popcorn) off-center on the tray (not in the middle) because the heating is better, plus the extreme heat is not always applied to the same spot in the tray each time.
Food placed in the middle will not cook as evenly.
Good luck, and we appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Emerson MW8987B/W Microwave Oven
GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 16, 2007 | Whirlpool GH7145XF Microwave Oven
LG Microwave Logo
57 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
