MFC-240c will not scan - Office Equipment & Supplies
  • 2 more comments
  • nazu May 24, 2008
    the printer wont let me scan any documents and keeps asking to be reset
  • garyreno Dec 11, 2008
    Same problem here.
  • khoi89 Apr 10, 2009
    it keeps telling me to "check connection"
  • nmiao Apr 11, 2009
    I have got the same problem. MFC-240C does not scan.
    Guru:
  • 1,342 Answers
Here is the Brother Support link for your printer
Here is a link to FAQ's for scanning with MFC-240c
Posted on May 06, 2008
CarlGehrke
  • 169 Answers
SOURCE: Not able to scan to pdf file with Brother MFC-240C
What you seem to want to do is not possible. Let me explain:
A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
What you CAN do:
a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
c) Use your favorite PDF creation program to make a file with the image embedded.
Carl
Posted on Dec 10, 2008
Rivernet1
  • 67 Answers
SOURCE: Can not scan to mac
This issue might be caused by a compatibility issue between Apple's Security Update 2008-002 and Rogue Amoeba software. If you have installed one of Rogue Amouba's applications: Instant Hijack, Airfoil, Audio Hijack Pro or Nicecast, please see the information on Rogue Amoeba's web site regarding this issue.
http://www.rogueamoeba.com/utm/2008/03/19/security-update-2008-002-compa tibility-fix/
If you do not have any of these applications installed, please contact Apple Computers for assistance.
Posted on Dec 02, 2008
  • 135 Answers
SOURCE: Brother MFC-240C
All Vista drivers for your MFC-240C Here:
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/dlf/download_index.html?reg=eu&c=gb&lang=en&prod=mfc240c_all&type2=1&os=74&flang=English&dlid=
Please be so kind as to rate my response thank you.
Posted on Mar 04, 2009
  • 4886 Answers
SOURCE: My brother mfc 240c won't scan!
Do you have the full-featured software installed or did you use the OS's built-in driver? (Sometimes, the minimal driver only runs the printer.) Check here for drivers (just choose your OS): http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc240c_all
The most common issue for scanners is a communication error. Try a new USB cable, try a different USB port. If you have a USB hub or print server connected between the computer and the MFC, try a direct connection. Scanners require two-way communication and often fail even when the printer functions are fine.
Check if your scanner has a scanner transport lock and unlock it (only some models have this).
I hope this helps.
Posted on Apr 20, 2010
  • 9 Answers
SOURCE: How to scan on a brother MFC-240C printer?
Use your paint program under accessories.
Start - accessories - paint - file - from scanner or camera - choose your device and follow the directions
Posted on May 29, 2010
How to scan on brother mfc-240c
Two methods are:
1) Insert a USB Flash drive into the machine.
Select the SCAN function.
Follow the prompts on the display (asking for filetype, etc)
2) With the machine directly connected to a PC via a USB cable you can use the Brother scan software that came with the machine. If you do not have the disc that came with it you can get the software from their website.
Here's a link to Brother's SCAN support section
May 31, 2011 | Brother Multi-Function Center MFC-240C...
Will it be able to scan on adf
Yes, the MFC-240C can scan up to 10 pages through the automatic document feeder. Just make sure the pages you scan aren't stuck together or stapled, or they will jam.
Jun 02, 2010 | Brother MFC 240C All-In-One InkJet Printer
May 28, 2010 | Brother Multi-Function Center MFC-240C...
I have a MFC-240C printer all in one and I need to scan a doc
Scan all 4 of them in, you can use adobe acrobat to combine them or search for a similar program via google that will combine pdf's, they're out there and they work great!
Jan 21, 2009 | Brother Multi-Function Center MFC-240C...
Incomplete scanning and copying
is your scanner glass clean?
if not, clean it tells u hell in the user guide
Jan 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc 240c
you have to install the paperport software. This should be done when you have run the whole mfl-pro suite.
go to progr. /scansoft/paperport/ click scanner and simply scan into the paperport desktop.
Feb 28, 2008 | Brother MFC 240C All-In-One InkJet Printer
Error code cc3-205-03031f02 will not scan
What model do you run? Is it a brother mfc 240c or something diffrent?!!
I ve never seen such an error code for brother mfc 240c printers!
Dec 27, 2007 | Brother Multi-Function Center MFC-240C...
1,193 people viewed this question
k24674
