Any one heard of quiet air heat pumps - Heating & Cooling
  • kevy114 Aug 27, 2010
    Sorry, I mean,t quiet air as in n a make of heat pump
    Problem Solver:
  • 19 Answers
Absolutely, there are many choices. Look for the dB (decibel) rating in the manufacturer's specs.
Here is a good chart for comparison purposes: http://www.sengpielaudio.com/TableOfSoundPressureLevels.htm
Posted on Aug 27, 2010
Is there a reset for the computer other than unhooking the battery or a reset for the fuel pump?
Could be the pump. Do you have the pressure at the fuel rail? If you have pressure and spark, then the noise you heard was probably lifter tap. No oil or over heated.
Jul 30, 2015 | 1999 Dodge Durango
I have a new Amana PTH15E PTAC. When heat is used, sometimes is quite but sometimes sounds loud (like window AC), why?
when its quiet its the electic heat thats being used when its loud its the heating pump and the heating pump is what saves you energy and they can be a little loud when its on its normal. I work on these units at a hotel
Jan 02, 2011 | Amana PTH123B25AJ Heat Pump Air...
My new Laars JVS 225 boiler make a whining noise when heating up. It does it on all zones. This was a replacement for a Teledyne Larrs that had a leak but ran quiet. IPressure is 15 lbs and temp is 155...
My new Laars NeoTherm boiler (NTH150) was making a whining noise soon after install. The noise was audible through most of the home. Replacing the air/gas blower solved the problem. Correct sizing of pumps is also important to reduce (water-flow related) noise. Having done all that my Laars boiler still isn't particularly quiet in its start-up and (modulating) operation. It should NOT be located below or next to a bedroom.
Nov 19, 2010 | Heating & Cooling
I AM LOOKING TO BUYI AN AIR CONDITIONER / HEATER LIKE THEY HAVE IN HOTELS. WHERE MAY I FIND THEM
It sounds like what you are looking for is a Packaged Terminal Heat pump go to this site http://www.hvacdistribution.com. They also sale units like the one you have pictured(through the wall air conditioner).If you want to shop around then search for the first one and then through the wall with heat or a heatpump.
Nov 12, 2010 | Emerson Quiet Kool 5JV53 Air Conditioner
Quiet air heatpump model qa18hrin1 is only blowing out cold regardless of what the temperature is set to
The reversing valve is stuck in one position and could indicate a bad valve or a bad control board.
Aug 01, 2010 | GE Quiet-Aire Ductless Heat Pump Split...
Fujitsu 18000 goes into defrost once an hour at 28to 32 degrees outside temp. trying to maintain 70 degrees inside . test run was ok on start up. just installed 3 days ago .. vacuum out the lines. lost...
what is the lowest outside temp manufacturer suggests? Heat pumps are not very good when it gets good and cold... call the installers and see what they have to say for you.
Feb 21, 2010 | GE Quiet-Aire Ductless Heat Pump Split...
Ductless heat pump - how many and where located in home
i live in sandwich and am mitsubishi expert
please call
508-420-3922
yellowdog services
to much to type here
Sep 26, 2009 | GE Quiet-Aire Ductless Heat Pump Split...
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
