My Marshall G80R CD Amp 80W Amplifier is experiencng some difficulty. When I am playing it at concert volume, using a Zoom 1010 effects pedal, it keeps massively reducing volume and losing effect. Each time I seem to do a different thing and it goes back to its original sound. I am playing it through a fender squire stratocaster.
techman
  • 3130 Answers
SOURCE: Losing volume on channels
I am afraid not. That crackling is a component in one of the solid state amp circuits starting to fail. These are all soldered into the printed circuit board. This could be a difficult repair to find an intermittant component. Depending on how old the unit is and how much it cost will factor in on if you have it repaired or not. Rule of thumb is that if the unit is two to three years old and cost less the 200 to 300 bucks you should not invest more then 100 to 150 bucks into it. Good Luck
Posted on Mar 16, 2007
larry james
  • 287 Answers
SOURCE: Reduce output
make sure your tape monitor switch is not on.
Posted on Sep 18, 2007
SOURCE: Yamaha DSP-A2070
Check the 'front mix' switch on the back, set it in off; main level on max.
Posted on Sep 10, 2008
Scott Ellin
  • 558 Answers
SOURCE: I've had a Pioneer SX-R9
The general fault come up with the AV recievers is:
My A|V receiver says, "OVERLOAD" and shuts off, what should I do?
Poor wiring connections, bad wires or a bad speaker may cause this. As you increase the volume, you will increase the amount of current you are drawing from the receiver. To troubleshoot this issue, try the following:
1. Disconnect each speaker wire connection. Inspect for any frayed or damaged wiring and replace it.
2. Check the impedance of the speakers; make sure they are properly rated for your stereo. In most cases, they need to be 8 ohms. Only a few Pioneer receivers will support lower impedance.
3. If the problem still continues, try these steps:
1. Turn the receiver off.
2. Remove one speaker.
3. Turn the receiver on.
4. Increase the volume.
If the receiver overloads, repeat steps 1-4 (selecting a different speaker each time). If you disconnect a certain speaker and the receiver no longer overloads, have this speaker checked at a service center. It could have a bad speaker component, like a tweeter, sub-woofer, or even a bad crossover.
Regards
Ellin
Posted on Oct 01, 2008
SOURCE: Low speaker volume for B Side Speakers...
burn radio output
Posted on May 13, 2009
Low volume on my marshall
I am very new here and don't know how to answer a question to a specific problem so I will write about the most common problems that I have had over the decades doing guitar amp repairs. If you find that your amp is extremely low in volume and then suddenly comes back to normal- check out the effects return [or power amp in] jack. Especially in Marshall amps-these corrode and your signal dies. If there is loud noise such as hissing and crackling with no guitar patch cord in the input jack- the input jack is likely at fault. They normally have switching contacts that ground part of the input circuit when the 1/4 inch male plug is disconnected. When this in is corroded or too weak to make normal contact, you can get these symptoms. If your amp is a solid state Marshall or Fender and there is a random buzzing sound with no guitar signal connected- hit the side of the amp and listen for the buzz to go away or become louder-if it does, this usually means that the connections are loose at the two large filter capacitors. In one or more Marshall amps, they use a filter circuit in the low voltage power supple for the preamp tubes. If you encounter a dead Marshall[the model escapes me now] remove the circuit board and resolder the four connections at the bottom of the bridge rectifier. If you have any other amplifier repair questions you can email me direct at computerlen@hotmail.com.
Nov 14, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
I've only had my Marshall MG102FX combo a few months and I love it, but lately it has been cutting out while I'm playing, towards the end of our set (normally about 2 hours after switching...
NEVER CONNECT PEDALS THROUGH THE EFFECT LOOP OF AN AMP. They are NOT design to work at the same signal levels !!! ONLY use effect units that are design to be used in amp effects in the amp effects loop/
Aug 01, 2011 | Marshall Amplification Marshall MG102FX...
CAN I PLUG IT IN TO MY AMP
Yes the output jack socket can be used either to:
  • plug in a set of headphones for personal listening / practice
  • to connect to an amplifier.
The zoom pedals use either a mono or (tip and sleeve) or stereo (tip, ring. sleeve) 1/4 inch jackplug - i.e a standard guitar lead.
You should plug it into a line-level or high impedance socket on your amp. With the pedal in play mode you can adjust the output level (gain) to match the input requirements of your amp by rotating the 'Value' knob (top right)
Feb 26, 2011 | Zoom B1 Bass Multi Effects Pedal
Can the zoom g2g plug straight into a speaker cabinet
No. You will need to use an amplifier, home stereo, P.A.etc. I would recommend insertion in an effects loop if your amp has one.
Dec 13, 2010 | Samson Technology Zoom G2g George Lynch G2...
Marshall DSL 100 - volume fades away and gradually comes back on
IF this is a vacuum tube unit, these symptoms are that of a tube that the heater is intermittent, that is it cools off due to a break and then liights again.
Open the back and observe the heaters in the tubes. DO NOT be fooled by some that have TWO heaters in them. (use a mirror if necessary) A single one that comes and goes can cause the problem and the voiration can make it come and go. This behavior in a tube is NOT somthing readily spotted in a tube checker. The delay in fading and coming back would be the delay in warm up following a heater going out and cooling.
Feb 14, 2010 | Marshall Amplification Marshall MG250DFX...
No output from my Marshall MG15DFX
could be effects module or sound output i.c. also check send and return jacks
Feb 04, 2010 | Marshall Mg15dfx 15-Watt Combo Guitar...
I have a 30th special edition,,1962,,1992 marshall amp and want to know how to set up,,has jack plug in back,,not sure where it goes,,??
Well if there is anything you need to insert into the effects loop IE, wah pedals, noise gates etc etc the return is the output of the effect and the send would go to the input of the effect. As far as inputs those are all on the front panel.
Jan 08, 2010 | Marshall Amplification Marshall MG250DFX...
Marshall Amp Sound Problem
try cleaning the send and return sockets with switch cleaner or WD40
Jan 31, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Amplifier sound difficulties
When I turn on my marshall amplifier its makes this unusual, anoying sound. it sounds like a small motor or a fan going. the sound of the amp is good but its just makes this motor sound when I switch it on. can you help me find the problem.
Mar 25, 2008 | Prime 40 Watt 2 Channel Lead Electric...
206 people viewed this question
 Grubhead
Grubhead
