Question about Hayward SAND FILTER, PRO SERIES
Water is leaking out of the back flush hose when the pump is turned on not when it is off what can that be the gasket?
  • 760 Answers
First with pump off be sure multi-port valve is turned to filter. Then start pump. If you then have water coming out of the waste outlet, then you're "spider" gasket may be bad. You will need the model number of the valve (SP710 or Sp 715 as an example, there are many other models) With the pump off you can remove the top of the valve. Depress handle before removing screws. Be sure the valve top is in the correct position when re-assembling. Only switch vavle with pump off, and handle depressed.
Posted on Aug 27, 2010
Does anybody have a video link on how to flush the cooling system on a GM 3.1L SFI OHV 6cyl motor? I need a vid for this particular motor cause mine is still overheating & i have looked everywhere.
flushing a cooling system is the same method as any other motor
do it without the thermostat fitted
or water pump opening
sacrifice an old radiator hose to adapt a garden hose fitting
for radiator flush
air in system fix
your thermostat housing has no air bleed valve
no top radiator cap
old school way
heater on full
run motor till thermostats fully open
burp radiator hoses
wait till water is running up into over flow bottle without bubble
replace cap
turn off heater
correct level in over flow bottle
why still over heating
you fitted everything i would have ... yet still overheat
possibles
leaking inlet manifold gaskets
hose clamps loose
cooling fans spinning too slow
thermostatic fan switch faulty
aluminum radiator is a big one
air ..fins bent or some water channels blocked
or possible head gasket leak
Nov 02, 2016 | Cars & Trucks
I am installing a new water pump for a 1999 Honda Accord and in the cooling system there is a lot of fluid like slim and rust I have ran water through the system letting it run through the water pump
did you open the rad drain and flush that way or take the hose off the bottom of the rad. sounds like you may have more than just water pump issues could be head gasket, take off oil filler cap there is white milky slime it could be head gasket make sure you locate the leak or it will all be coming apart again anyway. make sure the timing marks are correct when you put it back together
Jan 19, 2015 | 1999 Honda Accord
Have leak coming from under machine wandering about gaskets
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Jul 27, 2012 | Whirlpool Washing Machines
Water leaking from hose inside washing machine casing
Jul 02, 2012 | GE Washing Machines
Dishlex 500e water comes out the bottom when turn it on otherwise workes great what has happened
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Jul 09, 2011 | Dishwashers
Heater not blowing heat only cold
Check the coolant level. It is common for the intake gaskets to leak causing the coolant level to drop. The first thing to stop working when the coolant gets low is the heater. Top off the coolant and determine where you are leaking coolant whether it be the intake gaskets, hoses, radiator, water pump, etc.
If the coolant is full what does the temp gauge say? Once the vehicle is warmed up it should read around the 200 degree mark. If its below 190 than the t-stat is stuck open. Replace the thermostat.
If both of those are fine and the coolant looks like mud than your heater core is plugged. You can try back flushing it with a water hose. Remove both of the heater core hose and use a water hose to flush out the heater core. This may take several tries before you start to feel some heat.
Nov 14, 2010 | 2001 Chevrolet Blazer
Overheating caddy! Restricted flow from the top of the block. What I have done. New thermostat, engine coolant sensor, New hose's top, bottom and by passed heater core. Removed all hose's and radiator...
you don't say what year caddy. but older models (especially the 4.1L) did have a problem with intake manifolg blockages and gasket leaks. if that sounds like it could be your problem try replacing the intake manifold gasket, and clean out the inside of the manifold while it's off either manually, or by having it put in an acid vat at a rebuild shop or napa center
Sep 08, 2010 | Cadillac Eldorado Cars & Trucks
2001 kia sportage is over heating but has no leaks. the radiator has been flushed but is very rusty inside. The water is rusty inside the radiator. We have checked the resevoir, it is fine. the water...
Rusty is from running a bad or no mix of coolant. (PH level is off) You may have a water pump that has corroded impellers, and can't move the coolant as well any more. I would start by making sure to flush the engine block again, and make sure you flush water through every possible hose, and where you can get at it.
Jun 14, 2010 | 2001 Kia Sportage
89 honda civic lx overheating
Thats my guess, one hose leak, two head gasket, three, crack in head somewhere. Of course make sure the thermastat is working. If it is seized thats a problem to. If you get the head off make sure it is resurfaced before you install the head gasket. Good luck
Jun 05, 2009 | 1989 Honda Civic
Proper method on coolant system flush
Best way is to buy a flush kit. It is an adaptor that you put in your heater hose and can hook up a garden hose to. You cut the hose and put this device permanently in the line. Remove the thermostat, don't put the new gasket in there yet just put the outlet pipe back on and bolt it down. Run the car when cold with your hose running for about 10 minutes with the radiator drain valve open on the bottom of your radiator and the cap loose, water should come out of the drain valve and the radiator cap. This will flush your engine adequately, why waste money on distilled water, save that for topping off your battery. Turn off your engine continue to allow water from your hose to flow as long as you are seeing any thing other than clear water flow until it flows clear. Turn off the hose, put the cap on the flush port you installed. the port stays under your hood and allows you to flush your engine as needed. Let the water drain through the drain valve. Put in a new thermostat, with a gasket this time. Refill with water and antifreeze as directed in your manual. You should be good to go.
May 21, 2009 | 1997 GMC Jimmy
Hayward SAND FILTER, PRO SERIES Logo
202 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
