Question about LG WM-2277HW Front Load Washer
My LG WM2277HW washer always gets an IE error. To finish the wash, I change the setting to Speed Wash and punch Rinse Spin. Sometimes, I get lucky and the wash finishes. Most of the time, I get another IE. What's happening?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error IE water inlet error which occurs when correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes. To start with you can try to clean the filter if this wont help then you'll have to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 27, 2010
LE error code on my WM1814CW,it fills with water and drains but doesn't turn.
The LE code indicates a motor overload. The washer will not spin to avoid damaging the unit. First unplug the washer and let the motor cool for 30 minutes. When you plug in the washer, check if the unit has been reset.
The error often occurs if you use a non-HE detergent or too much detergent. In that case, do a Rinse and drain steps. Set the Spin Speed to No Spin by pressing that key several times. When that finishes, open the door and remove all of the clothes in the tub. Close the door and set the washer to Rinse and Spin. Run this program several times until you see no suds in the wash tub. If the LE code returns when the washer is empty, check the drain pump and filter for foreign objects. The error can also occur if you wash too many items at once or too heavy a set of items. Try doing a smaller load in the future.
If the error persists, then the tub motor, bearings, motor shaft or wiring may be damaged. Here is the parts diagram and one vendor's list of the replacement parts: http://www.searspartsdirect.com/lg-washer-parts/model-WM1814CW/3204/0153200/K0810333/00002.html . If your washer is under warranty, contact LG.
I hope this helps.
May 25, 2015 | LG Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Lg intellowasher wf t8501tp
My washer WF-T8501tp shows a PE error code.
Can anyone tell me what's wrong with it
Nov 17, 2013 | Washing Machines
Annoying LG Tromm wm2277hw "LE error" won't go away.
Might be "tE" error code. Thermistor error. A $6 parts and pretty common and causes the symptoms you described.
Mar 02, 2017 | LG 4775er2002a Door Hinges for Wm2277hb...
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
GETTING AN ERROR CODE - LE ON MY WM2277HW
A common reason for an LE code is choosing a high spin speed on a bulky/ very heavy load. Try a cycle with a lower spin speed. If you still get the LE code, especially if it does not even do the wash tumbling, then replace the Hall sensor on the motor.
Feb 01, 2011 | LG WM-2277HW Front Load Washer
My LG washer, model wm2277hw gives me the OE on the display. I have cleaned out all the possible areas where it could be clogged around the pump, but still makes a bad noise when it gets to the rinse...
You may have a broken pump impeller - you will have to order the whole pump (the filter on this machine allows BIG stuff through and it can ultimately damage the impeller)
Have you run this through diagnostics and determined if it is the drain or recirculating pump?
To run diagnostics:
Press and hold the "Spin Speed" and "Soil Level" buttons at the same time - then hit the power on the button
All lights should display - Press the Start Pause button throught the following cycles:
1 - Tumble clockwise
2 - Low speed spin
3 - High speed spin
4 - Prewash inlet (let it run for a few seconds to put some water in the tub)
5 - Wash Inlet
6 - Hot Water inlet
7 - Bleach inlet
8 - tumble counter clockwise
9 - Heater
10 - Circulation pump (see if your noise occurs here)
11- Drain pump (let this run until the tub is empty)
12 - Power off, finished
Once you figure out which pump, order the correct replacelement
Apr 27, 2009 | LG WM-2277HW Front Load Washer
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Aug 11, 2008 | LG WM2688HWM TROMM SteamWasher
LG WM-2277HW Front Load Washer Logo
197 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
