Question about Neurosmith ® Music Blocks®
We have the older version of the music blocks from 1998. Was in storage. we brought it out and put new batteries in it and it is not working. We cannot locate an on off switch? Please help? Is it broken or are we missing something? Thank you!
Flash player active x v12
no browsers stated, IE , edge, what?
no OS stated. XP?
no PC model stated, just mini (service tag on bottom has it)
hopeless,
(do now that many things like to block flash )
try running fire fox, and then put on opera brower.
see if IE , edge(w10) FF and opera all fail.
i bet one works. telling you why it does.
in most cases the browser has blocks setup.
or your malware or AV software doing that;.
ask ADOBE now to get older versions.
they will tell you the older one is a virus magnet and is blocked.
same with java and javascript.
old is bad, new is good.
forget 223Ghz... totally forget that.
Aug 16, 2017 | HP Mini Notebook
Tip
SD Cards and How to format them
SD Card types
Ever since their introduction in 1999, SD cards have continuously been researched and developed as the most practical solution for mobile storage. The SD Card Association regulates the cards, and the presence of their logo on an SD card ensures that you are using an officially certified product, compatible with most devices available in the market.
Different SD card types developed as technology started requiring more and more storage, as applications and files increased in size.
SDSC
SDSC cards were developed to improve the standard of the time, MMC. These cards had a storage limit of 2GB but at the time of their development that was quite an impressive value. The SDSC cards also featured an asymmetrical design to prevent users from inserting them the wrong way and damaging their devices. The cards also featured security circuitry for digital rights management content protection.
SDHC
Released in 2006, the Secure Digital High Capacity format presented the world with an upgraded version of the storage card. SDHC is considered to be the 2.0 version of the storage card. The storage limit was bumped up to 32GB despite having the same physical and electrical construction. These cards sometimes have incompatibilities with older storage cards, and this is due to the extensive modifications made to the CSD register.
SDXC
The Secure Data eXtended Capability format was released in 2009, defining the 3.01 specification of SD cards. These new cards support storage up to 2TB, which is an incredible amount of storage in such a small form factor. Besides the extended storage, the SDXC format brought many new features such as the Ultra High-Speed bus which allowed for faster data transfers of up to 104 Mbyte/s.
SDXC How to format an SD Card
on Nov 24, 2016 | Tablets & eReaders
Every time i put music onto my HTC Inspire, some of my other music disappears off of it. It is completely missing and every time i try to put it back on something else goes missing. What is happening and...
Hi Whitefang.
It sounds to me like you have maxed your memory, so when you put on new files it deletes older ones.
Instead of using HTC sync for file loading just use Mass Storage and select memory card on your pc/laptop to upload files to any folder you wish. Make a "music" folder on your Sdcard and it will make things so much easier.
Also if you use the "Mass Storage" method your pc/laptop will tell you if your memory is full or nearly full.
When you plug in the USB cable into the phone use the connect to pc option instead of HTC sync.
May 03, 2011 | HTC Inspire 4G Smartphone
My TRANS-IT USB Flash Drive is showing a problem 'cannot identify the capacity of the flash drive' and shows no spaces available
THIS HAPPEND TO ME TOO WHAEN I INSTALLED A NEW VERSION,
ITS OK IF U R WORKING WITH NEW VERSION.
NEW VERSION ONLY GIVES U ACCESS UPTO THE INSTALLED OLDER VERSION INSIDE.
GUST PLAY WITH LOG IN AND LOG OUT OPTION, IT WILL HELP U TO SOLVE UR PROBLEM.
BETTER TO REMOVE SOFTWARE AFTER ACHIVING UR FULL CAPACITY.
May 20, 2010 | TDK (CD-RW74HSFXS5) Storage Media
Hammond organ, L series brought out of lomg term storage problem
Lubricate with OFFICIAL Hammond oil immediately! Then let sit for a couple weeks. Manually turn the generator and add lube as needed until free. If bearings still sticky, put a bit of CRC226 on them individually and free them, then lube with the hammond oil via the wicks.
CRC226 is available at Home Depot in electrical dept.
Also, go to the organforum.com for additional help.
Jan 24, 2010 | Music
I downgraded itunes from 8.0 to 7.5 now when i try running itunes it says (The file "i Tunes Library.itl" cannot be read because it was created by a newer version of itune). how do i fix that?
You can fix this by updateing. Apple puts blocks in place to cause the older versions to stop working. They do this because people learn how to unlock the music they buy on itunes so Apple has to create new locks. To avoid this, never update. They claim to be fixing bugs but they are really making it difficult to remove the locks. They are also updating itunes for the itouch and iphone.
If this didn't help, you can go into chat on Apples website and they will tell you more about the error code being thrown. Good Luck,
Dec 30, 2008 | Apple iPod MA446LL/A MP3 Player
Can't put music or pictures on my phone
For some reason the packaged Pc Suite software doesn't work for music tranfers.
I don't know if this applies to all ks360 versions; I have the Vodafone version.
To be able to transfer music you have to set your usb connection to Mass storage.
Go to settings>connectivity>usb connection>mass storage
Then when you connect the phone to the pc the computer might prompt you with 2 windows about what action to take on the connected usb devices - the two being your phone's internal memory and your phone's memory card.
In case you are not automatically prompted you have to manually find the phone's drives.
(From an ealier post)
go to your Windows desktop and double-click My Compter.
It will show your what drives are connected to you computer.
It should show both the internal memory of your phone and the memory card in your phone.
Both will be referred to as removable disks. Choose the bigger one.
right-click>properties will show you the size.
My phone doesn't have MSN though other versions have it; just like other versions have Live Square and others don't. Even the included games/demos differ according to carrier and region.
Do not create a new folder for your mp3s. Save your music in the Sounds folder.
(not even in the Others or Documents folder or else the phone won't see or play them)
To find the music on your phone go to the menu by pressing OK:
my files>external memory>sounds
Dec 28, 2008 | Lands Phones
Lights come on but nothing shows its black.lens looks good
I have seen a few of this model and the tubes were gone in each case. Best way is to check if HV present at tube - get someone who knows what they are doing to take a look. If it is the tube, it will be expensive to repair. Unscrewing the lens may reveal that the inner surface of the tube has dark marks, also indicating possible tube damage.
Nov 13, 2008 | Famous Trails Calypso FT700 Monocular
Neurosmith ® Music Blocks® Logo
224 people viewed this question
Top Neurosmith Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Neurosmith Baby Gear Expert? Answer questions, earn points and help others
