I need to see what the View Sonic Optiquest Q19wb audio cord looks like because, I don't have enough space and I want to try out the built-in speakers.
  • 11,361 Answers
It is an audio cable with mini stereo phone plug at both ends that you can get it at Radio Shack.<br /> <img src="http://www.fixya.com/uploads/images/DA9418A.jpg" /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a rel='nofollow' href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
Posted on Aug 27, 2010
How do I turn on the sound on the optiquest q9b2 monitor?
Regarding your concern, just connect the audio cable from the LCD to your computer. The audio cable should also be connected to the audio port found at the back of the LCD.
I hope we fixed it. Thank you for visiting FixYa!
May 03, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
Please help me my optiquest q19wb model #vs11443 is shuting off aftre 1 second i opened it and no capacier were damadged what is wrong... the unit is not old 2 years i am not rich and want to save...
The usual problem with this symptom is an CCFL power supply failure. The inverter is the board that powers the backlights so you can see what is on the screen. If you look really close and with a flashlight, you may be able to see the dark shadow of the image on the screen. Without the backlight, the LCD is useless.
You can get parts from places like http://www.lcdalternatives.com/ or eBay. Search for the model number and "repair" (e.g. "Optiquest Q19wb repair") on eBay.
Apr 12, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
Viewsonic Optiquest Q19wb lcd Monitor goes blank after 2 secs. A couple of posts say replace the 1000uf 16v Cap My problem is i can't find them on the pcb (where are they?)
Look at the board where the AC power connector comes in that is the power supply board, there are more than one versions so it nay not have the same caps value.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic/Optiquest monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Post pictures or send them to me budmrtn@aol.com
May 15, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
My Monitor just stopped working. No pop, no fade, just dead. Oh, sorry it is an optiquest Q19wb says manufactured in 10/2006. bought 1.5 years ago at best buy. Worth trying to fix or dump it??
Optiquest is the Viewsonic low end products. You can take it apart and look inside.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 30, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
ViewSonic Optiquest Q19wb LCD Monitor goes blank after 2 secs. A couple of posts say replace the 1000uf 16v Cap, My problem is i can't find them on the pcb (where are they?)
sgcb1971, There are lots of pics on web for you to view and then you will know what to look for. Electrolytic filter capacitors are not to hard to spot on a "switch-mode-power-supply"/"ccfl inverter supply" combo board. Why don't you visit YOUTUBE for some video clips of "lcd monitor disassembly" and "lcd monitor repair" . Also try www.ccl-la.com/badcaps.htm for more clues as to just what to look for. Ya know , you need a soldering iron to replace them if they are bad!!! It's not like changing batteries in a flashlight 12fixlouie
Mar 28, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
Q19wb Monitor Replacement Part Numbers Needed
Look on eBay for "Optiquest Q19wb repair" or "Optiquest Q19wb power"
This is a common failure mode. You can either buy a set of capacitors and solder them in, or buy a replacement power supply board if you cannot solder.
One eBay seller notes the power board as an ILPI-025, which is common among the following models:
Power Board ILPI-025 For LG W1934S & Viewsonic VG1930WM & Optiquest Q19WB & Acer AL1916W Ab etc
Model:ILPI-025 REV:E 79069140
May 29, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
I have a viewsonic optiquest monitor Q20WB and buttons not workin
Sounds like that monitor has reached the end of the road. I would recommend purchasing another monitor, other than view sonic. Purchase a Dell..they are great!
May 13, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
