Question about Nokia N95 Cellular Phone
N95 black creen - Nokia N95 Cellular Phone
  • Nokia Master
  • 6,993 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
When a phone screen is blank, has a white screen, etc, there are three things that could be the cause;
  1. Bad/defective screen and the solution is screen replacement
  2. Software/Virus problem and solution is to flash the phone
  3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Good luck.
Posted on Oct 06, 2010
When itry to use my camer s creen is black
It is Easy you have to clean the web cam or check in to control panel the good install of this chek it some times with a upload driver go to work
Feb 05, 2014 | Computers & Internet
Analog tv lg
Hi, its a low voltage power supply problem, and a horizontal output stage failure. I can only advice you to seek professional technicians, its to lethal for you.
Jun 02, 2013 | Computers & Internet
Can't get past the ematic style innovation screen
Me ematic. Tablet it has. U problem. When. It. Turning it gets frozen the thoeh creen
Feb 07, 2013 | XO Vision Ematic eGlide 7Inch Touch Screen...
System board security chip
http://en.community.dell.com/support-forums/desktop/f/3514/p/19348729/19758657.aspx
Oct 19, 2012 | IBM ThinkPad T42 Notebook
My screen turns black when i turn it on it flashed the creen for
first should do is first try to trim the monitor or meaning mounting a LCD or external CRT monitor to see to fix laptop are behind
Jul 22, 2009 | Computers & Internet
I need a program that will help me about my n95 to work gps!!! thanks
Please help me to unlock my N95 cell IMEi Code is 358998013431211
May 31, 2009 | Nokia N95 Silver/Black Phone North...
N95
if you have the original N95, it is located at the left edge of your phone
but if your using the new N95 [8G] (black) - there is no memory slot for it has already an 8gig storage.
Mar 31, 2009 | Nokia N95 Cellular Phone
My n95 screen black
its the lcd connector, the little thing that attaches under the keypad, just get a new ribbon
Jan 03, 2009 | Nokia N95 Cellular Phone
Repair
ur screen is damaged dear may be in u\ur pocket try to readjust creen conector may be it works otherwie go to change it
Mar 22, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
231 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
